Sponsored by: Innova
AVIC Z2 install
Old May 1, 2008 | 08:06 PM
WDDarts's Avatar
WDDarts
Default AVIC Z2 install
Working on the AVIC Z2 DD install on my C5 (as I write this). When doing the video bypass do I hook the light green pbrake wire to ground or does it need to be hooked to a switched ground?
BTW I am going to use the download off of AVIC 411 which to my understanding has bypassed the video lock out feature (fingers crossed here).
Thanks for any advice or help.
Webb
Old May 1, 2008 | 11:09 PM
Vegas Vette's Avatar
Vegas Vette
You have to mod the Harness and ground them both the bypass of 411 is the right info. You may have to download the firmware and install it into the Z2 to make the two wire ground bypass work. Good luck mine works fine...
