Sponsored by: Innova
Subwoofer / amp C5 setup questions
Old May 9, 2008 | 01:52 PM
njvette98's Avatar
njvette98
Default no
you would just need the 4 channel amp
http://forums.corvetteforum.com/show....php?t=2007429
i think this might be a good solution, no you do not delete the rear speakers the front speaker and tweeters get run in parallel with the supplied crossover
Old May 9, 2008 | 01:54 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by Fasthotrod
Well... kinda.
Just because the speakers are made by the same company doesn't mean that they are 'sonically matched.' They would need to be the same driver. Same size, shape, materials, etc...
It's one thing to have your mains, center, and surround channels using the same exact drivers... but in a car it's a non-issue.
You are (probably) only going to listen to 2-channel stuff, right? (Music in stereo.) Unless you plan on running DTS/Dolby with a 5.1 system in your car, I wouldn't think twice about mixing/matching speakers.
Mark
For stereo imaging, its important to have good Mids and Highs in the front because your ears are more directionally sensitive to higher frequencies. The rears in both home and car audio are used for ambiance. For this reason, many people use less expensive coaxials in the rear saving money for high end components in the front stage.
Old May 9, 2008 | 02:03 PM
mike_mds's Avatar
mike_mds
St. Jude Donor '09
Great....I know the FAQ covers stuff like speaker sizes, so I'll read up on that info there.
Thanks for all the info guys. Once I get the mechanicals finished on the car this year, I'll be turning my attention to the full audio system in '09. I'm really jacked up about getting the subwoofer in by Memorial Day weekend!!!
Old May 9, 2008 | 03:10 PM
Fasthotrod's Avatar
Fasthotrod
Originally Posted by mike_mds
I have the sneaking suspicion that the Audio section of the forum is going to end up getting me in as much trouble as the C5 Parts for Sale section....
How many channels of amplification am I going to end up needing when I replace the stock speakers? I know right now there are two speakers in the doors and two in the hatchback area...do the back 2 get replaced if I go with a component system in the front? I know the front would be replaced with two tweeters and two woofers, but the back speakers I have no clue about....
I hear ya... I recently got hooked up with some local Vette owners and now I've sunk cash into a Z06 rear end. All I need to do is get a new stall converter and install it.
Ant paint my calipers.
And put on long-tube headers.
And a cat-back.
And....
Here are my thoughts: If you want good quality sound, don't bother with rear speakers. I don't have them in my car, and I really don't miss them. I had a set of Infinity components in the rear, but they pulled the Soundstage back too far. The rears are too close to your head, so the music from them arrives first, then the front. Even with the drivers turned down low, you'll have that issue unless you run time alignment.
As for the channels of amplification: I run my front components with their crossover. (Passive.) Two channels up front, one sub channel.
I am considering running an active crossover. I will need four channels up front: L&R mids, L&R highs. (Plus a sub channel.) That means I need either two amps, or one large 5-channel amp. The cool thing is, I'll be able to adjust the crossovers, and time alignment of every driver. Ultimate flexibility... some minor complexity.
In your case, so long as you run your passive crossovers, you will need 3 channels as a minimum. If you do decide to run rears, then you'll need 5 channels.
Mark
Old May 9, 2008 | 03:19 PM
Fasthotrod's Avatar
Fasthotrod
FRONT:
Coupe/FRC/Z06: Front can handle 6.5" components easily... but be careful of tweeter placement due to the door panel:
If you can, try and get them as close to the 6.5" driver, or do like I did and mount them lower:
In this picture, I left the inner grill fabric off so you could see the driver placement.
REAR
Coupe: 6.5" driver.
FRC/Z06: 5.25" driver.
Be careful on the depth of the magnet on the rear speakers... the gas tank fill tube is right behind the left rear speaker.
If you decide to build your own box:
http://www.fasthotrod.mypldi.net/images/vettebox.pdf
I made up a drawing to help.
Mark
Old May 9, 2008 | 03:25 PM
mike_mds's Avatar
mike_mds
St. Jude Donor '09
Question on having no rears....how does this effect listenability (if thats a word?) with the targa top off cruising down the highway at 65+ mph? Are the front speakers alone producing enough volume that I won't have to crank them to the breaking point to overcome the hurricane level wind noise?
Old May 9, 2008 | 03:49 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
at 65+ you'll have to crank pretty much any system with the top off. It's not as bad as a vert because the hatch acts as a wind screen. Even with 100w per channel, i still have to crank mine up an additional 3-4 levels. If you plan to cruise with the top off a great deal, you should look into mounting the tweeters in the A pillars either midway up like Kale or in the corners like me. This will raise your soundstage and make the music sound like it's coming from directly in front of you instead of fom your feet.
Old May 9, 2008 | 08:40 PM
mike_mds's Avatar
mike_mds
St. Jude Donor '09
You guys are absolutely killing me!
I come into the audio forum for the first time to ask a little advice on adding a subwoofer to the stock system, and now I'm already pricing replacing everything except for the head unit in the next month.
Bunch of zealots....y'all are worse than the forced induction crew!
Old May 9, 2008 | 09:22 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I ran without rear speakers for a year. I just added some in the past 2 months, I am so glad I did. The music now sounds like it is in the center of the car and not the front.
I tuned the rears to have just enough fill to make it like I was in the middle of the music.
Old May 9, 2008 | 09:37 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
Thank you very much. Now go out and buy a bunch of unnecessary stuff and install it already. Jam out dude.
