Sponsored by: Innova
advice on replacing bose in 85
Old May 9, 2008 | 02:49 PM
viii's Avatar
viii
Default advice on replacing bose in 85
Hello, I have the bad bose system and am looking to replace it with something decent. the key is that I want the head unit to be flush with the dash. I spoke with crutchfield last night and they tell me many units will fit flush if i remove some support bracket behind the current bose set up. I then use a c4 adaptor to accomodate gaps etc and install the new head unit. Does anyone have any experience with this procedure? Any risks to removing the support bracket behind the factory head unit.... the bose system in my 85 is awful. thx
Old May 9, 2008 | 02:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
cutting the bracket back there is pretty standard no reason not to
its a support piece for the factory radio
Id look into a decent radio and speakers all around and maybe an amp for em if you really wanna be able to crank it up
If u need any install help let me kno
Old May 9, 2008 | 05:24 PM
viii's Avatar
viii
excellent - thanks for the offer on install help. I am right near by you in Arlington Heights. I 've been reading that I might have to rewire to put in aftermarket speakers - not sure why that would be necessary .is that true?
Old May 9, 2008 | 05:44 PM
Kale's Avatar
Kale
85 is about the easiest car in the world to run new wire in. I'd highly suggest doing it. Get some 16 gauge from Walmart
Old May 9, 2008 | 08:44 PM
pentavolvo's Avatar
pentavolvo
bose systems need to be rewire becuase they have a common from the factory that wont work right
Old May 10, 2008 | 01:07 AM
pentavolvo's Avatar
pentavolvo
ill shoot u some info tomorrow on stuff you can go with
goals, budget, requirements etc
Old May 10, 2008 | 11:17 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Good idea to have Penta help you, he knows what to do. Wish he lived near me.
Randy
To advice on replacing bose in 85
