Keep in mind you won't get but 20% of the benefit unless you are willing to completely rebuild your doors into speaker enclosures. I dont mean damping, i mean complete rebuild.
For less and less woryr,
Focal polyglass/access
i wouldn't go that low... good dampning can get you more than 50% of the benefit. If it's as low as 20%, then all speakers would sound like crap, just like the rear speakers ....
Go to a good shop so they can build a fibreglass enclosure that has the right curves and fits around the window... or never roll your window down ... a couple of layers of dynamat extreme for the door and door skin should be fine....
The benefit of uber speakers in a door install is lost regardless of damping material. Damping material is not going to fix off axis, reflection, and most enclosure issues.
