Sponsored by: Innova
Amp recommendations?
Old Jun 3, 2008 | 12:40 PM
rcs128's Avatar
rcs128
Default Amp recommendations?
What's a decent but reasonably priced 2-channel amp in the 50W @ 4 ohms range that doesn't run too hot? A lot of the reviews I see for smaller amps mention how hot they get. Or am I better off getting a higher-rated amp and not pushing it as much?
Forgive my noob questions... I just want to get something that will mount in the rear well (C5) and run something like JL Tr650-CSIs.
Old Jun 3, 2008 | 01:00 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
This pioneer is actually a great small and budget oriented amp, ive used em a few times and no problems didnt seem to run warm at all
http://www.sonicelectronix.com/item_...+GM-3300T.html
http://www.sonicelectronix.com/item_...se+EA2000.html
eclipse has always made quality amps as well
Old Jun 3, 2008 | 01:58 PM
Homer3D's Avatar
Homer3D
To be honest, with an amp that low powered, heat really isn't an issue. I have a 500 watt mono block amp that barely heats up. (JL 500/1) So you are good with any of the "normal" brands...ie Alpine, Kenwood, Pioneer, MTX, etc...
Old Jun 3, 2008 | 02:00 PM
rcs128's Avatar
rcs128
Sweet. That looks like just what I'd need. Thanks for the expert insight and the link -- truly appreciated.
Old Jun 3, 2008 | 02:01 PM
rcs128's Avatar
rcs128
Good to know. That's really helpful info.
Rich
Old Jun 3, 2008 | 02:25 PM
pentavolvo's Avatar
pentavolvo
yeah i shoulda added that at that size unless you are trying to overdrive the amp heat shouldnt be an issue
To Amp recommendations?
