Sponsored by: Innova
1990 Bose - Displays Code SCV?
Old Jun 3, 2008 | 02:11 PM
ZFORME's Avatar
ZFORME
Default 1990 Bose - Displays Code SCV?
The head unit works great CD/Cassete, but there is no sound anywhere. I have read some stuff in the FAQ. I assume it is the amplifiers for the speakers. Where are the amplifiers located? I have checked the fuses already.
What does the code SCV mean?
Old Jun 3, 2008 | 08:25 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Speaker amps generally do not go bad all at once. It is either the relay, or the CDM has taken a dump. I would check out the relay first, I am in work and do not have my FSM, so I cannot tell you which one it is. They are located, I think, under the dash on the drivers side. I'll post when I get home.
Randy
Old Feb 19, 2009 | 01:39 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
relay I am not sure of but the CDM is up under the Dash between the air vents and the glove box. I am pretty sure. There is a thread here somewhere that explains how to get to it.
Old Feb 19, 2009 | 02:59 PM
RandyJ75's Avatar
RandyJ75
To get to the relays, you will need to remove the hush panel on the pass side of the car. There should be several relays attached to a bar that runs along the dash, just look up and you will see it. I am not sure which one is for the radio, check your FSM. If you don't have one, sent me a PM, I'll look it up for you.
Randy
To 1990 Bose - Displays Code SCV?
