C4 - What needs to be modified?
I have searched and have found different answers and some are from years ago. I think I'm going to go with Alpine (never had problems in the past) speakers. I was planning on 6.5" in the door. Now will these fit right in or will I need to change or modify anything. I was going to go with 6x9's in the rear. I want to be able to keep the stock speaker grills in the car for a stock look. So with that what will fit in the doors and rear with out modifing anything or cutting up the grills.
HU I was going to try to find a JVC KD-AVX33. It is 50x4
I'm ready to start buying the equipment...thanks in advance guys.
To fit the 6-1/2" speakers into the doors, you will need to remove the speaker "pods" that are in there now, and make a set of speaker plates.
To fit 6x9's in the rear, you will need to do some work on the rear speaker pods, as the speakers in them are 6-1/2" round speakers. It is easy to put 8" subs back there, and the stock speaker cover will still fit over them, making it a completely stealth installation. You will need to run a small amp, which given your noise problem, would not be a bad idea. You should also consider doing some sound deadening to quite down the inside of the car.
http://forums.corvetteforum.com/show....php?t=2036636
Randy
I already have 2 Alpine amps and 2 stinger bass blockers from a previous system.
1- MRV-500T V12
1- 3522S
