Sponsored by: Innova
Cable type?
Old Jun 15, 2008 | 07:38 PM
Dr Steve's Avatar
Dr Steve
Default Cable type?
Is it best to run twisted pair or shielded (coaxial) type wire from the head unit (line level output) to the amplifier (in the trunk)?
How would you route the wires? Through the center console/waterfall or through the door sill area?
I have a C6 Vert.
Sorry these are basic questions. but we all stare somewhere.
Thanks!
Old Jun 15, 2008 | 07:43 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I have a C6 Vert.
Thanks!
Use shielded!!!! A car is a very noisy electrical environment and you're transferring an analog signal. Run it down the center console and under the waterfall and carpet in the trunk to your amp. That way you can use the door sill for the power wire and keep them separate - running the power wire for the amp next to the signal wire is a sure-fired way to get noise.
Buy a good quality set of RCA's. I used Stinger that I got from darvex.com. A lot of people here have used Knuconceptz (spelling?) as well.
Old Jun 15, 2008 | 08:53 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
basically what he said... down the center FTW
Old Jun 15, 2008 | 09:26 PM
Dr Steve's Avatar
Dr Steve
THANKS! Now I'm ready to rock and roll!
Old Jun 15, 2008 | 11:52 PM
Kale's Avatar
Kale
+1 for down the center. I like JL's entry level cables, they work extremely well - and most importantly - have a short connector.
To Cable type?
