Sponsored by: Innova
not loud enough
Old Jun 18, 2008 | 08:36 PM
enos44's Avatar
enos44
Default not loud enough
Im in the process of installing a JVC headunit in my 99 FRC. I purchased the peripheral interface, believe I have everything hooked up correctly but when I turn up the volume I have to turn it up all the way to hear it and its not very loud and starting to get distorted. I have messed with the individual gain ***** on the peripheral piece and they are maxed out. Are the Bose amps not turning on or something else? Im pretty sure I have the remote amp switch hooked up. Thanks
Old Jun 19, 2008 | 01:30 AM
Z28Johnny's Avatar
Z28Johnny
IMO I think you should just do it right. Replace the factory speakers and use an amp. You could get amp and speakers for around $300 +
Old Jun 19, 2008 | 01:39 AM
enos44's Avatar
enos44
that is in the future but for now I just want to use my headunit and ipod but thanks
Old Jun 19, 2008 | 11:17 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
how exactly do you have it wired and what are the switches set at
Old Jun 19, 2008 | 12:17 PM
enos44's Avatar
enos44
have it wired as the instructions say matching the four speaker's wires together through the peripheral unit, have the grounds connected (should i run a seperate body ground into them?) have the switches set to wired and wired (gets little bit louder when set to rca, which i think means that the bose amps arent turning on) and have the individual speaker levels maxed out. Thanks
Old Jun 19, 2008 | 12:23 PM
pentavolvo's Avatar
pentavolvo
the input should be wired and set the output on rca
the amp is turning on, if it wasnt you would have no bass output at all from ur bose subs. The amp is only for bose subs, if your regular speakers arent getting loud enough then you need more power
Old Jun 19, 2008 | 02:04 PM
enos44's Avatar
enos44
how do i get more power? I turned my headunit up all the way and the speakers are barely audible
Old Jun 19, 2008 | 02:28 PM
pentavolvo's Avatar
pentavolvo
you sure u wired all this right???
Old Jun 19, 2008 | 04:18 PM
nextime's Avatar
nextime
Your radio may have an internal amp it it, I shut mine off on my Kenwood on accident and had similar issues.
Old Jun 19, 2008 | 04:23 PM
pentavolvo's Avatar
pentavolvo
with it off he should have no sound... post exact model numbers of what u got and ill see what i can find
Old Jun 19, 2008 | 04:41 PM
enos44's Avatar
enos44
I have a JVC KD-AR800 head unit, SVEN4 peripheral interface and a wire harness adapter. Thanks
Old Jun 21, 2008 | 07:05 PM
enos44's Avatar
enos44
anybody?
Old Jun 21, 2008 | 08:46 PM
scott_fx's Avatar
scott_fx
wire your ipod or other device that has rca outputs directly to the SVEN4 peripheral interface. this will tell us if it's a problem with your head unit or the sven4.
Old Jun 22, 2008 | 01:10 AM
enos44's Avatar
enos44
ok I will try that but I think I am just going to put an amp and new speakers in
Old Jun 22, 2008 | 10:53 AM
nextime's Avatar
nextime
I hope you get it working.
Old Jun 22, 2008 | 11:51 AM
pentavolvo's Avatar
pentavolvo
if i recall the sven4 should only be powering the door subs the rest of the system is ran straight off the speaker level outputs from the radio
Old Jun 22, 2008 | 03:01 PM
enos44's Avatar
enos44
ok which wires are for the door subs? and thanks again for your help
Old Jun 22, 2008 | 04:02 PM
enos44's Avatar
enos44
ok I just rewired it bypassing the interface and Im still just not happy with the sound, so I will be installing an alpine 4 ch amp and a set of 6.5 components up front and idk about the back yet. So I guess I now have another question (ya I know) what all is requried to install a set of 6.5 components up front and use the stock speakers from the alpine amp? Thanks again
Old Jun 22, 2008 | 04:14 PM
nextime's Avatar
nextime
I am using an aftermarket Kenwood Stereo with the Bose Speakers. The Bose Speakers sound like Crap.
Anybody who uses any aftermarket radio needs to ditch the Bose speakers.
To not loud enough
