I was wondering about the possibility of using a hard drive to store music in cd format instead of mp3 format. I'm a bit of a music purist and not fond of compression. I look for audiophile recordings and have an SACD and DVD Audio player at home; mp3 don't cut it. I could store a lot of full cd images on a 160 (or bigger) hard drive and use that instead of a cd changer. Does anybody know of a head unit or interface that would let me do this? I was thinking of putting a powered hard drive in my storage bin to replace the cd changer.
There are a few units out there with USB interfaces that can do such a thing. A few pioneers, iirc. You can use a notebook hard drive. it's easier on power, more vibration tolerant, and can fit anywhere.
Thanks for your advice.
The notebook drive sounds like a good idea. Do you happen to know the model No.(s) of a USB equipped Pioneer? preferably single DIN? I guess the next question is whether the USB puts out enough juice to run a hard drive, otherwise I would need an independent power supply for the drive.
most dont put out enough power i recommend a laptop sized usb drive as they usually have a 2 pluged pigtail incase you have an older comptuer and it cant power it so you plug on into the radio and the other into a usb to cig adapter plug and burry it in the back of the dash somewhere
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Kenwood also offers USB connections on some of their units. I run a KVT-819 with an iPod and a 8gb jump drive. I think "SimpleTech" makes a 60gb flash drive.
I happened on a reference to the JVC KD-NX 5000. It is single DIN and has a 40 G hard drive, 24 gig is available for music storage, the rest is for nav. I'm thinking this may be the way to go; especially if you could mod it to throw in a bigger drive (would have to figure out how to format and set up the new drive).
why not go the car pc route? you can have loss-less bit perfect playback and wont have to worry about powering the drive. you can also have it sync to your home library automatically via wi-fi
