Sponsored by: Innova
Final amp rack install. Warning: Bling deficiency.
Old Jun 22, 2008 | 03:10 PM
Kale's Avatar
Kale
Default Final amp rack install. Warning: Bling deficiency.
My "temp rack"
And then...
After letting the car sit in the garage for a week while exploring my options, I decided to go the hidden wire route.
1/2" board, routed out:
Being 1/2", I couldn't cross two power wires, and I didn't want to cross power and RCA so I had to design around that.
Power wire detail:
I wanted to use silver for tweeters, blue for woofers, and blue/silver for subs. I couldn't find all those colors, so I bought 18ft of blue/silver monster cable. I had to "devein" the stupid clear tube on the wire, then pair blues, silvers, etc so the color scheme is as I wanted it. Marked negative with heatshrink. Marked "left" with silver paint on the heatshrink. I feel dirty for buying monster :/
Everything terminated with a quick disconnect, for ease of install.
Nice and clean. As light as possible.
The carpet runs all the way around it, so no worries about wire bleeding.
The bump under the right amp is the blade fuse for the EQ.
Ever seen an amp rack mounted to rear speaker locations? This required NO drilling through the carpet. 100% safe - no chance of hitting the gas tank which is directly under the rack.
Zoomed out completion views:
Amp cover: Stealth ftw.
Old Jun 22, 2008 | 06:37 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Turned out very nice!!!
I like the hidden wires too.
Old Jun 22, 2008 | 07:02 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Very nice... How do you like the Arc Audio Amps....
Old Jun 22, 2008 | 07:11 PM
Kale's Avatar
Kale
I'm a big fan of ARC. Had their original CXLs. The new Kar KS line is very good too.
Old Jun 22, 2008 | 08:16 PM
scott_fx's Avatar
scott_fx
needs blue leds
:-P
looks good
Old Jun 22, 2008 | 08:51 PM
rcs128's Avatar
rcs128
Very nice work!
Old Jun 22, 2008 | 09:18 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Looks nice, Kale!
Old Jun 22, 2008 | 09:20 PM
Kale's Avatar
Kale
Originally Posted by scott_fx
needs blue leds
:-P
looks good
There's one.
Old Jun 22, 2008 | 09:59 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Nice work
Old Jun 23, 2008 | 01:03 AM
BOXOLOGY's Avatar
0BOXOLOGY
Former Vendor
quite possibly the best amps out there for the money... good choice!
Old Jun 23, 2008 | 04:01 AM
D C's Avatar
D C
USMC (retired)
Old Jun 23, 2008 | 10:31 AM
Kale's Avatar
Kale
Future plans include removal of the ARC logo and getting something acid-etched into the amp covers.
Or possibly doing the amp covers in Lemans Blue... One says CORVETTE one has the Commemorative Edition logo... But not being able to paint the EQ would present an issue with that.
Old Jun 23, 2008 | 11:30 AM
SRTstyle's Avatar
SRTstyle
nicely done
Old Jun 23, 2008 | 11:37 AM
CraigE's Avatar
CraigE
Looks good .. nice job
I'm curious..... how did you secure the amps to the mdf ? I can see the screws. But do they screw directly to the wood, or screw into a T-nut or similar.
Old Jun 23, 2008 | 11:44 AM
Kale's Avatar
Kale
Just into the MDF itself.
Old Jun 23, 2008 | 11:51 AM
fej's Avatar
fej
Looks sweet bro Nice work and I really like the attachment idea. I would guess that there are a few screws holding that bracket in there? Shear out of 1/2" MDF and a single screw is pretty low.
Nice work man, hopefully you will leave it alone now and enjoy it
Did you make it down to Marv's? Really bummed I missed it this year, didn't have the vette system together, it still had the race tires on it from the last autoX, and I had about 6 other events that I could not get out of. I will be there next year with a Nav system for the 2500 and a HAT front stage though Need to figure out a sub idea still though in the crew cab ... don't like my options so far
Fej
Old Jun 23, 2008 | 12:11 PM
Kale's Avatar
Kale
Wait - marv's happened already? I thought they did that in september so I havent eveen looked at the BBQ threads yet.
Just one screw on that side. It doesn't move at all, even without the screws. But we know how good car accidents are at moving stuff. worst case scenario, if the brackets broke, there is 0 slack in the power wires, and almost no slack in the other cables.
To Final amp rack install. Warning: Bling deficiency.
Old Jun 23, 2008 | 05:22 PM
openhelix's Avatar
openhelix
Marv's was either this past weekend or this coming weekend...
Old Jun 23, 2008 | 07:40 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
awesome work man
Old Jun 23, 2008 | 09:11 PM
fej's Avatar
fej
Marv's was Saturday the 21st. Apparently there were some great installs and systems this go around.
I gotta make the next one, hopefully Marv has it again, as I know it is a ton of work.
Fej
