Sponsored by: Innova
Help! Installing Relay with GMOS-04
Old Jul 6, 2008 | 03:11 PM
openhelix's Avatar
openhelix
Default Help! Installing Relay with GMOS-04
I have an 07 C6 (no bose, no onstar) and am trying to get the GMOS-04 harness setup. It says I need to use a relay (I have a ratshack 275-001 as per the FAQ) however I'm not sure now where to mount it. The wiring instructions are outlined in the gmos-04 instructions but do I need to mount the relay in the under hood fuse box? where should I get power from and run ground to?
Thanks!
BTW, I searched and checked the FAQ, nothing specific on where to put the relay or how to wire it up.
Old Jul 6, 2008 | 03:58 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thanks!
You wire it in with the GMOS-04 in the dash. I thought I did include this copy & paste from the Metra install instructions:
A Relay is needed in the 2005-2007 Corvette. You will need to cut the blue/white wire in half
between the 16 way Molex and 24 way gray connector.
• Connect the blue/white wire coming from the 16 way Molex to pin 85 of the Relay.
• Connect the blue/white wire coming from the 24 way connector to pin 30 of the Relay.
• Connect pin 86 of the Relay to Ground.
• Connect pin 87 of the relay to fused 12 volt constant wire. Using tape or a wire tie securely the
Relay from moving around in the dash.
That tells you exactly what you need to do with the relay & the GMOS-04.
Old Jul 6, 2008 | 04:00 PM
openhelix's Avatar
openhelix
Thanks komoman. I was thinking I needed to put the relay in the fusebox for some reason. I wired it up with some quick connects.
Pin 87 connected to the yellow wire on the harness with a T-tap and Pin 86 to the black ground wire.
Old Jul 6, 2008 | 11:04 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gmco is the ideal harness for a nonbose/nononstar FYI in case u continue to have issues
Old Feb 19, 2009 | 09:44 PM
Weasel 435's Avatar
Weasel 435
Thanks!
I'm doing a similar install on my C6, and in the instructions it says to use a SPDT relay, whereas that item number leads to a SPST relay. I've been looking high and low for a SPDT as per the instructions, but I can't seem to find any. Where should I be looking for such a part, and is it necessary to use a SPDT, or will a SPST serve a similar function?
Old Feb 20, 2009 | 02:43 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
the GMOS-04 comes with a relay
Old Aug 23, 2011 | 07:21 AM
sajonf's Avatar
sajonf
I am installing this setup in my 2011 with Bose and the instructions for the GMOS-04 and the relay have a discrepancy.
As shown above the GMOS instructions say to connect the GMOS side (16-way) of the blue/white wire to pin 85 of the relay and connect pin 86 of the relay to ground.
My relay shows pin 85 is ground (black) and pin 86 is 12v switched. They are basically reversed from the GMOS instructions.
So should I assume that my relay is wired differently than the GMOS instructions state? I would think they should all be pretty standard but maybe not.
If I take that approach here is how it would be wired:
Car side (24 pin) of blu/wht wire - connect to pin 30 of relay (yellow - described as common)
GMOS side (16 pin) of blu/wht wire - connect to pin 86 of relay (described as +12V power)
Connect pin 85 of relay (black - described as ground) to ground
Connect pin 87 of relay (brown - no description - normally open, connected to #30 when coil is energized) to yellow 12V constant
Is this correct? Any help would be appreciated. Thanks!
Old Aug 23, 2011 | 09:26 AM
markcz's Avatar
markcz
Pins 85 & 86 are the coil, one needs to be grounded and the other is the controlling wire (remote trigger from gmos). It doesn't matter which one is connected where.
Pins 30 & 87 are the 'switch'. Connect one of them to battery and the other to supply whatever equipment you're powering. Again it doesn't matter which one is where.
Old Aug 23, 2011 | 11:13 AM
sajonf's Avatar
sajonf
I was making it more difficult than it needed to be.
Thanks a bunch!
To Help! Installing Relay with GMOS-04
