Sponsored by: Innova
C4 Install ? / Pix request
Old Jul 10, 2008 | 07:57 PM
jsavoy's Avatar
jsavoy
Default C4 Install ? / Pix request
Has anyone used this tuner bypass kit or is there another harness I should to replace the NON BOSE head unit in my 96?
I would prefer not to splice into the factory harness if I can avoid it. http://forums.corvetteforum.com/show....php?t=1898671
http://www.installer.com/item/displa...hp?it=70-1856)
Has anyone installed a double DIN system in a C4 and willing to post pix of the unit installed? Thanks in advance...
Old Jul 10, 2008 | 08:23 PM
StealthLT4's Avatar
StealthLT4
I just spliced into mine, so I can't really help there. However, it really isn't hard at all. On my BOSE 96, it was just splicing into 4 wires, all on the same harness. Easy as cake.
I photo-documented my install pretty well, and you can see it in these threads: The first one is fabbing the front speaker enclosures for 6.5" components, the 2nd the rest of the install. Also, here is a pic of the unit installed. Since installing, I have moved it back a little bit in the dash, so it looks a little more flush.
http://forums.corvetteforum.com/show....php?t=2046825
http://forums.corvetteforum.com/show....php?t=2058190
Old Jul 10, 2008 | 08:32 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
that harness is the way to go
Old Jul 10, 2008 | 08:38 PM
jsavoy's Avatar
jsavoy
My search skillz suck... STealthLT4, THX for the pix / links.
Old Jul 11, 2008 | 09:58 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
First time I saw the second part of your install. Very nice work.
Thanks for taking the time to document your work.
Both parts need to be attached to the C4 sticky.
Old Jul 14, 2008 | 03:38 AM
Eakster's Avatar
Eakster
I also have made my own loom, and came across this $50 one which the retailer tried his best to sell to me. I would say get it if you're not confident cutting/ joining wires. I imagine it just plugs straight into the receiver loom that's in the bin behind the passenger seat.
I wanted to save $ and have only what I needed and I've learned a TON by reading the forum and doing it myself
Actually the hardest part has been tearing the interior apart without breaking or losing anything
To C4 Install ? / Pix request
