Sponsored by: Innova
Need a power distribution block for 18 AWG wire!
Old Dec 29, 2001 | 03:46 PM
C5Noir's Avatar
C5Noir
Default Need a power distribution block for 18 AWG wire!
I would like to get a power distribution block with one 18 AWG input and 3-4 18 AWG outputs each with a fused link to each wire. Do they make them this small? Thanks.
Old Dec 29, 2001 | 05:42 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Need a power distribution block for 18 AWG wire! (C5Noir)
I've seen them at electrical supply stores. Bussman makes them, kinda pricey though. Have you tried radio Shack as well?
Old Dec 29, 2001 | 09:52 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Need a power distribution block for 18 AWG wire! (JoeyG)
What are you trying to distribute to?
Old Dec 30, 2001 | 06:23 PM
Radio Joe's Avatar
Radio Joe
You should be able to get that at any local Audio store or radio shack.
REMEMBER- Your input wire needs to be able to handle the draw of all 4 wires that you split it into. If 18 awg is only enough to handle the current of each accessory, then your input wire must be big enough to handle 4 lines all drawing that current. in other words, if each line draws 5 amps and you have 4 lines, then the input wire into your junction box must be able to handle 20 amps. The input power wire should be hooked to the battery and must be fused within 1 foot of the battery. WITHIN ONE FOOT!!!!!!!! without fusing it within 1 foot, you run the risk of shorting the wire and burning your car to the ground. Even though the junction block has fuses in it, it still must be fused within 1 foot. (have I said 1 foot enough yet???? :lol: )
Have fun with your project.
To Need a power distribution block for 18 AWG wire!
