Sponsored by: Innova
C6 Z06 Amp ground location
Old Jul 26, 2008 | 10:30 AM
Medriver99's Avatar
Medriver99
St. Jude Donor '07-'09
Default C6 Z06 Amp ground location
Where is the best and closest place to ground an amp
in the C6 Z06. Amp will be mounted on the rear wall of the cabin.
Just asking because of the the aluminum chassis.
Mike
Old Jul 26, 2008 | 11:38 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i ground to the factory ground under the drivers or passenger side rear pillar
Old Aug 14, 2008 | 08:48 PM
SeanMo's Avatar
SeanMo
St. Jude Donor '10-'11
Am I wrong or are z06 batteries in the rear? If so why not ground there?
Old Sep 1, 2008 | 02:40 AM
Madvette Motorsports's Avatar
0Madvette Motorsports
Former Vendor
If you pull up the carpet on the rear passenger side, the battery ground cable runs to the spot Penta was referring to under the pass. side B-pillar, the rail behind the seats. You can ground to the battery as well... depends on the location of the amp ultimately, as you want your ground to be as short as possible.
Old May 26, 2016 | 12:00 PM
Marco Matos's Avatar
Marco Matos
I've been looking for pictures, but no luck. Anyone has a picture that can share? I'm gonna tackle this this weekend.
Thanks!
Old May 26, 2016 | 08:55 PM
markcz's Avatar
markcz
B pillar ground bolt is only a few inches off the floor, on the rear wall, IIRC next to the seat belt roll under the plastic trim.
Carpet pulls out/down easily, and plastic trim pops out with just a bit of effort.
Old May 31, 2016 | 10:38 PM
Marco Matos
Thanks! Found it!
To C6 Z06 Amp ground location
