Been gathering parts for several months and finally got my *** in gear and started doing stuff. Here's a couple mockups of the amp board with an Audiocontrol DQXS, Butler TD475, the Helix xovers and some "overkill" Knukonceptz distribution and fuse blocks in case I decide to add another amp:
Got some cheap speaker plates off eBay and modified them with an angled tweeter mount:
Raw:
Painted with tweeter cups mounted:
Got the left door speaker mounted, speakers are Helix RS6 bi-wired to the rear mounted xovers in case I decide to go active:
Taped and tie wrapped all the wiring cause I want it to look clean
if you want to add a little bling to it, replace the black fan with a led computer fan. i used blue and the combination of the blue fan with the orange tubes (leds) looks awesome
Thanks for the comments! I ran the wires over the hump because it was a more direct route and the carpet has more than enough space to swallow any wiring I might throw at it. Scott FX, thanks for the suggestion on the fan, I might just throw a red LED one in there to match the lighting on the HU Mount. Anyway, I finally got it done, here are some more pics:
An old Eclipse 55040 deadhead in an HUMount:
Mounted:
Amp rack wired and carpeted:
In the car:
And a pic of the NVTHIS sub box with a JL 8W7:
Head unit all lit up:
Man I love the way it sounds! Clear and full without being harsh. Sub sounds a bit bloated, I may try a lower xover point or fiddling with the EQ more but other than that I'm happy with it
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Mounted:
In the car:
Setup looks great Eric! Once you get that sub dialed in, you will be set.
