Sponsored by: Innova
D3 Unit Won't Play Sound (HELP!!!)
Old Jul 30, 2008 | 02:30 PM
LS3 Zeus's Avatar
LS3 Zeus
Default D3 Unit Won't Play Sound (HELP!!!)
Hello All,
My D3 has stopped playing sound and I don't know what to do. Everything has worked fine for about 5 months now, but today when I was driving the sound went dead. If I turn my car on the sound will come back on for 3 minutes then go off again. I tried it again during my break and the sound came on for about 20 seconds then went out again. All of the setting controls are fine, I really don't know what to do.
Any ideas?
Old Jul 30, 2008 | 02:31 PM
rcs128's Avatar
rcs128
My only guesses that maybe the harness for the audio outputs is loose. Or if you have the sound running through an amp, maybe it's not grounded right and is getting hot/cutting out?
Old Jul 30, 2008 | 03:00 PM
LS3 Zeus's Avatar
LS3 Zeus
Thanks. Are those the only two options? I'm guessing the third can be that the unit itself went bad.
Old Jul 30, 2008 | 03:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
or maybe more details on how its all hooked up what equipment you have what interfaces etc
Old Jul 30, 2008 | 03:21 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Default Overload?
My first guess is that you are overloading the amp. It heats up and quits,,, cools off and plays again (after shutting off head and restarting).
I did that a long time ago. I had the wrong impedance speakers. A partially shorted/grounded speaker cable might also do the same thing.
Old Jul 31, 2008 | 01:05 PM
naschmitz's Avatar
naschmitz
This happened to me right after I did my install. I had an exposed splice that was shorting to ground and the amp would shut off to protect itself.
Old Sep 15, 2008 | 05:42 PM
USAF_C6's Avatar
USAF_C6
I am having a similar problem with my Z-2 All of the sudden. Although in reverse. I get no sound when I start the car then all the sudden while driving I will get sound and all will work normally for as long as I like until turning the car off...
My Setup:
AVIC Z-2, with Bluetooth and iPod unit, connected to the stock Blose amp and speakers.
Been working wonderfully for over a year! Not sure where to even look... though I would guess maybe the Blose is not powering up? HELP!
Old Sep 15, 2008 | 11:07 PM
pentavolvo's Avatar
pentavolvo
exactly amp prly isnt powering up id check ur connections in the harness, then get voltmeter and see if u are getting 12volts on the turn on wire when the radio is on
To D3 Unit Won't Play Sound (HELP!!!)
