Sponsored by: Innova
12v switched and constant?
Old Aug 26, 2008 | 09:07 PM
PBogZ06's Avatar
PBogZ06
Default 12v switched and constant?
have 07 C6 and i want to hook up my Moto IHF1000 and it recquires 12v switched and constant.
anyone have any suggestions on where i can tap into.
I know i can get 12v from the fuse panel using an ADD-A-CIRCUIT and tapping onto the heated seats.
im wondering if the seats are a constant?
thoughts?
Old Aug 26, 2008 | 09:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
heates seats is switched... just probe around in fuse box there are numerous constant fuses in there
Old Aug 27, 2008 | 08:44 AM
PBogZ06's Avatar
PBogZ06
After posting this last night i did a test. I opened the windows and left the car overnight. before opening the door i reached in and moved the seats. so the power seats look to be constant. the heated part or switched.
anyone agree/disagree.
Old Aug 27, 2008 | 08:58 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Seat heaters and wipers are both switched and either can be used. IIRC the wipers fuse is in the smaller vertical box on the right with the cover.
Keep in mind that those will not be switched by RAP, so if you're in the middle of a conversation and shut off the engine your bluetooth will shut off even though the stereo is on. Getting a RAP power source involves installing an aftermarket module like the Peripheral GMRAP.
Old Aug 27, 2008 | 11:22 AM
PBogZ06's Avatar
PBogZ06
cool. thanks. i am planning on that upgrade after the fact. im going to hook this thing up and run around for the weekend to see if this is even usable. i mean road noise and whatnot. plus i can find a good location for the microphone.
thanks for the info
Old Nov 10, 2008 | 07:16 PM
PBogZ06's Avatar
PBogZ06
i found the following...
FUNCTION COLOR /POLARITY LOCATION
12V+ Constant Red / Black (+) BCM (C3, pin D1)
12V+ Ignition Yellow (+) BCM (C4, pin D3)1
2nd Ignition White, White/Black See notes1
Accessory Brown (+) BCM (C4, pin C8)1
2nd Accessory N/A
Start Signal Yellow (-) PCM(Pin 48 or 46)
Starter White, White/Black See notes1
Key Sense White, White/Black See notes1
Lights Brown (+) BCM (C3, pin A7)2
Door Pins Gray/Black, Tan/White See notes
Dome Light Gray (-) BCM (C3, pin A10)
Hood Pin N/A
Trunk/Hatch Orange/Black (-) BCM (C1, pin 55)
Trunk Release Tan (-) BCM (C2, pin 10)3
Lock White (-) See notes2
Unlock Same as Lock See notes2
Fact. Arm/Disarm N/A Remote only
Lock Motor Gray (+/-) BCM (C3, pin A4)2
Unlock Motor Tan (+/-) BCM (C3, pin B1)2
Horn Tan (-) BCM (C2, pin 14)3
Tach See notes At fuel injectors
Speed Sense N/A
Brake Lt. Blue (+) BCM (C2, pin 54)3
Parking Brake Lt. Blue (-) BCM (C1, pin 14)3
Reverse Lights Lt. Green (+) Driver kick panel
PCM – driver-side fender.
BCM – part of fuse/relay box on pass. side of center console.
C1-Gray plug, 72-pin
C2-Gray plug, 72-pin
C3-Red plug, 41-pin
C4-Lt. Gray plug, 68-pin
1Also at ignition harness.
2Also in driver kick panel.
3Also at switch.
SO i just need to tap into these two and Im done?
Old Nov 10, 2008 | 07:25 PM
heavymetals's Avatar
heavymetals
I would use the accessory brown wire.
To 12v switched and constant?
