ANYONE KNOW WHERE THIS HOOKS IN ON A 2005 VERT WITH
A NAV RADIO iS IT PRE WIRED FOR SAT OR DO YOU HAVE TO GO TO RADIO WITH T HARNESS IF SO HOW DO YOU GET TO RADIO?
MUCH HELP WOULD BE APPRECIATED
The factory XM unit on a vert is under the waterfall. You have to open the tonneau, remove the 2 T15 torx screws from the top of the waterfall, the two center-pop fasteners from the back of it where it secures to the trunk divider and a christmas-tree fastener on the passenger side near the bottom(hard to see, feel for it).
My car was factory XM so I don't know if the harness will be there for you or not. I have been told that the harness is there even in non-XM factory cars but I have no proof of it, sorry. You are going to have run the antenna because your car definitely does not have one.
