Sponsored by: Innova
C5 door speaker hole diameter.
Old Sep 3, 2008 | 03:06 PM
MJD's Avatar
MJD
Default C5 door speaker hole diameter.
Curious how large the hole is in the door for the stock bose woofer. Trying to get an idea of what else might fit.
Old Sep 3, 2008 | 03:28 PM
SublimeZ's Avatar
SublimeZ
From: Austin, Why are they tolling roads that are already paid for, Texas
This is what the hole looks like
This is with a 6.5" in the baffle.
Prolly going with 8's in mine.
Old Sep 3, 2008 | 03:46 PM
MJD's Avatar
MJD
What is the thickness of your mount and the spacer? Would a cutout of say 7.5 inches fit the hole?
Old Sep 3, 2008 | 03:51 PM
SublimeZ's Avatar
SublimeZ
2.25" at the bottom ring. Here's an 8" on the baffle for reference.
Old Sep 3, 2008 | 04:59 PM
scott_fx's Avatar
scott_fx
the factory uses an 8" woofer so you'll be safe a lot of us are useing 7"+ drivers, just make sure you seal and deaden the door
Old Sep 3, 2008 | 05:13 PM
Kale's Avatar
Kale
8" dyn driver in temporary mount
Old Sep 3, 2008 | 06:10 PM
SublimeZ's Avatar
SublimeZ
^ Damn you, Kale. Now I have drool all over my keyboard...
Old Sep 3, 2008 | 07:14 PM
MJD's Avatar
MJD
You have any issues with door panel clearance with your setup? And thanks a bunch guys.
Old Sep 4, 2008 | 12:06 AM
thmupr's Avatar
thmupr
Here is my 8" Kicker SSMB in the door. They are shallow enough to clear no problem.
Old Sep 4, 2008 | 09:49 AM
MJD's Avatar
MJD
How does that setup compare to stock? Did you go with this setup to avoid using a sub inclosure in the back? I'm thinking about doing something simular and placing the amp behind the seat so I don't lose trunk space.
Old Sep 4, 2008 | 10:54 AM
thmupr's Avatar
thmupr
I actually don't have it finished yet, so I have not heard it. I am planning to use subs, so these will only be playing 80hz+ . I really don't feel that they would be sufficient for anything below that, however I bet they will sound better than the stock set up by far.
Old Sep 4, 2008 | 12:47 PM
Fasthotrod's Avatar
Fasthotrod
As you can see in this picture, you have all kinds of room between the door and the panel.
I was able to mount a tweeter/cup about 1/4" or so off of the driver as you can see. I was also able to mount that big-*** crossover there, too.
If I had to guess, I would say that you have about an inch or so to play with between the door and the door panel.
These are the dimensions from the door to the inside obstructions, like the window, the track, etc...
Hope this helps.
Mark
To C5 door speaker hole diameter.
