I want to install an Amp with Sub for a little more bass.
I've burned out 2 amps already and I think maybe my ground source was not really a good ground. I used the metal tunnel under the console. I was also using a gmac2 and SVHGM4 adapters when I had the Bose still connected. I've installed a new Kenwood HU and replaced all the Bose Speakers and wires. Sounds Good. I don't want to fry another amp, so my question is "where should I ground the Amp?"
Any Advice is Appriciated.
Gus
Reason: Picture
I think you guy's are correct, some other issue.
I really think I may have mis-wired the Bose adapter, or it was defective, some sort of current backfeed? Since, I now have installed all New Standard Wire and Speakers, I will purchase a new amp soon and re-connect it, but I'm still going to use a different grounding source.
I was running a 4 ohm load to a 9" Sub from Elemental Designs
What really confuses me is that it worked great for 2 days before it quit.
