I just purchase an amp to power a 10" sub that I am pretty sure will fit in the sub box's 10" opening. Would this be advisable? I am not a big thumper, not sure if that makes a difference.
I would agree with my fellow audiophiles. Heat would be a main issue. Even if you are not a basshead, it will still get hot. Furthermore, an amp over time will need to be adjusted but when enclosed you do not have that availability. Put the amp behind the pass seat or under it. Thats a very simple install.
I will also have to agree with the others....... inside the box itself is NO place for an amplifier. I have my amp mounted behind my passenger seat, stays cool and its very easy to adjust.
