What components for the C5 speakers?
Also, what do you recommend for the rear speakers just to give a minor upgrade for what little sound comes out there?
Chris
Chris
Be careful when trying to install a couple of speakers in the door. While it will fit, you need to block the back of the mid like Thumpr did. (Good job, Thumpr... looks cool.) This prevents the 8" driver from sending it's sound through the midrange driver's cone.
You also need to be concerned about the way that the door panel blocks the speaker in the upper part of the door. As you can see in the following pictures, it starts to become a problem as the angle changes...
As you can see, because the area is so high and behind the door panel area, you run into a problem with the sound being blocked. Even if you had it flush with the front of the panel, you will run into issues with the off-axis response.
I addressed this by moving the tweeter down low and out from the door, like this:
As you can see, the tweeter is moved out to the edge of the speaker grill. Once everything is in place, you can't tell that I have them in there. Here is a picture to show you how it looks with the grill cloth removed. (I reinstalled the fabric after this picture was taken to make it as 'stealth' as possible.)
Hope this helps.
Mark
Hope this helps.
Mark
At first I thought that they were missing something... then I realized it was the distortion I was used to hearing.
The tweeters can be a bit bright... some people have replaced them with other brands to get things smoother. I haven't had that problem, and in the location that I have them in, they seem to be just fine.
They didn't like being crossed over at 90 hz with a 12dB slope with 75 watts a channel going to them... but with a 24 dB slope they just rock. No issues whatsoever.
I would recommend them in a heartbeat.
Mark
Mark
I hear the Apillar is the way to go with the tweet...would you agree or do you think the imaging you have is the better way to go with these tweets?
I tried the Alpine/Pioneers/Focla and the RSD's in my Denali had the SQ of the Focal but more midbass at a stupid cheap price level.I ran two sets in the Denali.Very surprising.Hard to come by though.The weave Pioneers are a good midbass also as above.
It depends on where you put them on the A-Pillar, and if you are running time alignment.
Up high will give you a higher sound stage, but you have to be careful about reflections from the glass. I have seen some that have put them pointing more downward than out/back. I suspect that the off-axis response of the tweeter is low enough and not reflecting off the glass?!?! I don't know for sure, because I never tried it.
Maybe some that have their tweeters mounted in the A-Pillar can chime in and explain the pros/cons of doing it this way.
Mark
Mark
