Sponsored by: Innova
Amp install problems...
Old Sep 30, 2008 | 04:13 PM
Shore's Avatar
Shore
Default Amp install problems...
Stock BOSE.Single 12" 2ohm load.BD1000 RF amp.
4ga power from battery to amp and 8 ga ground to rear seat bolt on floor.
Remote turn-on Dk green works correctly.
RCA split outter bare together to LT blue.
RCA L inner wire to Tan and R RCA inner wire Lt Grn.Wire taps used on radio harness.
I'm getting no bass and a thump when turned on and full excursion from the sub on powered off from HU.Good bit of hum if the amp gain is up but still no real bass response.
What am I missing here? I'll put up a pic to show the wiring behind the HU.
Old Sep 30, 2008 | 04:14 PM
Shore's Avatar
Shore
Wire taps in my hand go to nothing.Just moving them outta the way.
Old Sep 30, 2008 | 04:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sure u are at the proper plug... there are multiple plugs and the preouts come from one of the smaller plugs
Old Sep 30, 2008 | 04:21 PM
Shore's Avatar
Shore
Maybe not, if looking at the back of the HU it would be the left one.The remote works right.
Old Sep 30, 2008 | 04:27 PM
Shore's Avatar
Shore
Ya know what, you're right.I just saw the notes on the tan/blk.They are on the other side.
Is the dark green remote on that side also?
I tested it an got nothing for a remote turn-on.
Old Sep 30, 2008 | 04:40 PM
pentavolvo's Avatar
pentavolvo
read my post carefully, it says remote turn on is the big plug, the rest of the wires are the smaller one
Old Sep 30, 2008 | 04:41 PM
Shore's Avatar
Shore
Okay, I switched them over to the other side with the right wire colors.I left the remote turn-on to the other side and now I have plenty of bass but all my highs are gone from the stock....wth?
Old Sep 30, 2008 | 04:50 PM
Shore's Avatar
Shore
I had the - for the RCA to the +.Switched it and all is good.
No thump powering on or off.Pretty sure I hurt the sub with the full excursion earlier.It pops on bass it should handle easily.
I have another one so oh well.07 CVR12 DVC4.
Old Sep 30, 2008 | 05:28 PM
Fasthotrod's Avatar
Fasthotrod
If I were you, I would change that 8 AWG ground to a 4 AWG. No way a RF1000 amp should be operating with a ground that small.
Mark
Old Sep 30, 2008 | 05:49 PM
pentavolvo's Avatar
pentavolvo
the only way u would loose bass from stock speakers is if u somehow cut a wire
Old Sep 30, 2008 | 05:52 PM
Shore's Avatar
Shore
That will be my next move.
There is more to this story, I didn't start this mess.A shop did.After I saw what was done I started tearing into it.I wouldn't let them try to fix it.They got it wrong enough for me to say screw it.I'll do it myself.
They ended up with a line-out,like I said not to do.Then no terminal on the ground post.I even gave them the wire chart to follow and he decided not to.This how I got on the wrong side all along today...once the "other" side was brought up by PV it clicked.Everything else was just simple stuff.Learning curve.
I'll have aword with the shop owner tommorow.He happens to be a friend of mine for years.Not sure what happened today.
Old Sep 30, 2008 | 05:55 PM
Shore's Avatar
Shore
Apparently not,3 connections.two are + and one is the doubled up-.I had the doubled up - on one of the +.It was all mid-range.Odd but true.I saw it and switched it back and the highs where back.
Things we learn I guess.Even though i take the time to write down which wire to which both where white/blk wire tap leads and i got them backwards.
Old Sep 30, 2008 | 08:04 PM
pentavolvo's Avatar
pentavolvo
makes sense i never though if it that way
Old Oct 2, 2008 | 09:56 AM
Shore's Avatar
Shore
Well crap, we took the car out last night for the 1st time since the amp install and the driver front speaker whines.The sub box is not in yet so not sure if the bass will override the whine.It is pretty minimal but I can hear it at lower volumes.When the volume is all the way down it stops.
Is this a ground problem on the amp?
Old Oct 2, 2008 | 10:21 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Make sure there is plenty of room between the power cable and the RCA's. If the power cable is near the RCA's you will get a whine. This may or may not be the problem, but it's a easy check. Is the amp just running the sub?
Old Oct 2, 2008 | 10:37 AM
Shore's Avatar
Shore
The amp is for the sub only.The sub and box are not here yet.
The RCA's are on the middle of the car and the power wire is on the passenger side.The don't get anywhere near each other.
I don't understand why it is getting feedback with no sub hooked up.That I could understand.
Old Oct 2, 2008 | 10:52 AM
pentavolvo's Avatar
pentavolvo
never had that happen before, maybe a bad connection on the rca plug, or an rca shorting to ground
could always put a peripheral sven2 or sven4 in between the oem harness and ur rcas to isolate them from eachother per say
To Amp install problems...
Shore's Avatar
Shore
WaaHoo....sub box just got here.I'll go put the sub in and seal it up.It'll have to dry up 1st but at least I can tell if the whine is a problem or not.
It's just odd to get feedback like that.
Old Oct 2, 2008 | 11:49 AM
Shore's Avatar
Shore
I changed my mind and decided to run my dual 2-ohm CVR12 at 4ohm.2-ohm is overkill for the dual 4-ohm sub and the RF.Good forbid a 1-ohm set-up.That CVR wouldn't last at all.
The 4-ohm set-up was the way to go for me.The HU is not trying to catch up to the bass.
I get no feedback on the fronts or sub with the car off.Hmm..I still think that ground needs to go to the batt.
Old Oct 2, 2008 | 11:58 AM
pentavolvo's Avatar
pentavolvo
it has nothing to do with ur amp ground if you get whine up front even without the amp rca's hooked up, if your getting feedback in the speakers now that u spliced those rca's in there is an issue with ur splice or u are useing poor quality rcas or something like that. ive never one had an issue like this and ive done this well over 20 times in diff cars
