Does High Wattage(Amplifiers) mean better sound?
I was wondering if a 100WRMS amp is worse than a 250WRMS amp when tied to the same speaker... assuming the speaker is 75-90WRMS speaker?
Plus... I am looking for a good amplifier, 1 - 4ch amp for fronts and rears, and 1- Mono/2Ch for a pair of subs..(Not looking for a thump just clean bass) ...
I was thinking that a amp that is 100WRMS would be good for the front ...
And anything for the rear...
And 250WRMS for the sub...
I have looked at this JL Amp:
a 500/5
Specifications:
Available: November 2001
Front Channels:
100 W RMS x 2 @ 1.5 ohm-4 ohm
(11V-14.5V)
Rear Channels:
25 W RMS x 2 @ 1.5 ohm-4 ohm
(11V-14.5V)
Subwoofer Channel:
250 W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power:
<0.03% @ 4 ohm (F&R),
<0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R):
>108.5 dB below rated power
S/N Ratio* (Sub):
>95 dB below rated power
Frequency Response (front and rear):
5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel):
5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear):
>200 @ 4 ohm/50 Hz
Damping Factor (sub channel):
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(3 pairs of inputs)
Front Crossover:
fully-variable (50 Hz-5 KHz),
selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover:
selectable-slope HP (12 or 24 dB per octave)
Sub Crossover:
fully-variable (40-200 Hz),
selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (full-range or LP)
Bass EQ:
Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter:
defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit:
ambient effect for rear channels
Front and rear speaker output connections:
accept up to 8ga. wire
Dual mono subwoofer output connections:
+12V and Ground connections:
accept up to 4ga. Wire
Pic:
I think this would be perfect since the Vette is small and it has all 5 ch in one unit...
