Sponsored by: Innova
Switching NAV to single CD in 07 Coupe
Old Oct 14, 2008 | 07:28 PM
frankmp's Avatar
frankmp
Default Switching NAV to single CD in 07 Coupe
My car came with the factory NAV and BOSE system. I want to switch to a single CD and someone local took his out of his 07 coupe. Mine is like this one:
http://forums.corvetteforum.com/show....php?t=2105704 (post 10 I assume all NAV heads are the same for an 07 coupe).
He has offered his single CD head and a BOSE amp (part # 1590466 and 15903398).
So can someone advise:
-is the swap compatible
-mine is BOSE so is his also assuming its got the BOSE AMP (trust I don't need this?)
-is the swamp something straight forward that I could do?
-does a dealer have to perform some sort of electronic Voodoo
thanks for any feedback
Frank
Old Oct 14, 2008 | 07:33 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u dont need his amp, its a plug and play swap.
ur navi antenna is a total pain to remove so just leave it in, most ppl sell em without navi antenna. im not sure if ur sat radio will work or not.
dealer will have to use the techII to flash the radio to ur car, no way around it. u install it and the radio will work and power up once in accessory mode then after that the dealer must flash it
Old Oct 14, 2008 | 09:40 PM
frankmp's Avatar
frankmp
thank-you for your reply. So I should be able to remove my NAV, leave the navi antenna and stuff his unit in. Then go to the dealer and do the techII flash. Correct? Is removal of the NAV unit straight forward?
Frank
Old Oct 14, 2008 | 10:18 PM
pentavolvo's Avatar
pentavolvo
correct, once u get the counsel apart which this writeup shows u literally undo a few bolts slide the radio out and unplug
http://forums.corvetteforum.com/show...p?p=1551172269
Old Oct 15, 2008 | 07:54 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Sat should work just fine as well, assuming that single CD is able to control sat radio. The sat modules are locked to VINs, not to radios.
Old Oct 17, 2008 | 12:56 PM
frankmp's Avatar
frankmp
Single CD PN#1590466 purchased and now time to get to work. Can you also confirm that HUD will work and steering controls? I guess I'll plug and play the unit in accessory mod and see if it works.
thanks Frank
Old Oct 17, 2008 | 01:16 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
thanks Frank
Sorry Frank, can't confirm anything for you. My experience is entirely in replacing factory units with aftermarket, not using other factory components. Should that stuff work, I think so, but can't say for sure.
Remember, it's not going to work at all until you have a dealer Tech II program it. It will power up but will display some sort of error, not sure what it would be on that unit.
Good luck!
Old Oct 20, 2008 | 02:24 PM
frankmp's Avatar
frankmp
Default Tech2
As mentioned I need to see a GM dealer for the scan. I also heard some non-GM dealerships have these units. Talked to a few and they indicated they need a "code" of some type for the repalcement radio I've put into the car. Is this true? Or does the scanner just need to be plugged in and the radio unlocked (or is it locked to my car).
Also how long does it actually take to do (is there are specific part of the scan they go to so I can tell the tech if they are not fimilar with doing this procedure).....thanks for any input on this specific question....
Frank
ps- some dealers want a fortune for the service ($120)
Old Oct 20, 2008 | 03:12 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Previous generations of the Vette did have a master code, can't remember if it was C4, C5 or maybe even both. The C6 does not. Any service station with a Tech II programmer can change the VIN lock to your car. Unfortunately a lot of them just don't know they can....
Old Oct 21, 2008 | 02:55 PM
frankmp's Avatar
frankmp
Frank
Any feel for what this amp is worth? I did'nt take it but friend asked to see if anyone interested? I checked GMCanada and they retail for a crazy $600 Pm if interested....good deal.......
Frank
Old Oct 21, 2008 | 04:36 PM
pentavolvo's Avatar
pentavolvo
mgiht get 150 bucks for the amp they really arent worth much
Old Oct 22, 2008 | 08:33 PM
isnider's Avatar
isnider
I have the 6 disk in-dash with bose and it does show station and track changes on the HUD.
I want to buy your NAV btw.
Ian
Old Oct 22, 2008 | 10:57 PM
frankmp's Avatar
frankmp
Ian
No problem NAV just removed tonight...original offer still stands
Frank
Old Oct 24, 2008 | 05:50 PM
frankmp's Avatar
frankmp
thanks Frank
Job done, everything went like clockwork. Went to someone to do the GM TECK2 flash (dealers are ripoffs......most want one 1 hour of labor OR ~$100). A non GM mechanic shop had one and charged only $30). Watched him do it for all of 4 minutes!. Everything works. Now the as NEW NAV is out and available..........
Frank
To Switching NAV to single CD in 07 Coupe
