Sponsored by: Innova
PIE Auxiliary Input Connector, GM10-AUX Problem
Old Oct 30, 2008 | 12:37 PM
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
Default PIE Auxiliary Input Connector, GM10-AUX Problem
My battery died in my '04 and when I replaced it my Aux input stopped working. I was using it to play my iPod and now nothing. I tried to hit the cd changer button on the stock head unit but nothing happens.
It used to show the disk 1 track 1 display while playing the ipod but now it does nothing.
Anyone know a way to trouble shoot this? Anything I should check? I have already checked the connections between the harness and the Aux-10 and the RCA cables and they all seem tight.
Anyone?
Old Oct 30, 2008 | 12:42 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gotta try unhooking it from behind radio in c5 faq somewhere someone lists the exact steps to get it to work again
Old Oct 30, 2008 | 12:51 PM
Omega Man's Avatar
Omega Man
I guess that is worth a shot. I had a factory changer so I originally just pulled the changer and plugged it in the end of the factory harness.
I will go back through he FAQ.
Old Oct 30, 2008 | 01:01 PM
Omega Man's Avatar
Omega Man
Yep it was there. Post #9
Trouble getting your stock head unit to recognize GM10-Aux?
Sometimes if you loose power to the radio (dead/disconnected battery), or unplug the GM10-Aux converter, your stock head unit may not want to go to or stay on "Disc 1 Track 1" like it should. After getting some advice from other forum members I put thogther this little procedure that has worked for me every time so far:
-unplug GM10-Aux from Cor-Har changer cable
-let it sit overnight (a few hours at least)
-with car still off, plug in GM10-Aux
-let it sit for at least 10 minutes
-turn on car & radio, select changer on radio
-if it works (Disc 1 Track 1) you're done
-if it doesn't work, leave car running but turn off radio
-unplug GM10-Aux, then reconnect it
-turn on radio, it should work
Thanks again.
Old Oct 30, 2008 | 10:17 PM
Omega Man's Avatar
Omega Man
I followed the directions and it worked great. Thanks again
Old Nov 2, 2008 | 08:26 PM
jetsetvette1's Avatar
jetsetvette1
6th Gear
Hi Omega - thanks for the tip - my battery died in Jan this year and my GM10 / iPod setup didn't work since I got the new battery - I'd assumed the dealer knocked a wire or something but I didn't get round to taking it back in.
I tried your above steps from the FAQ (couldn't find the actual FAQ) and for the first time in over 10 months I actually heard music from the iPod over the vette's speakers!!
My problem is that it only lasted for about 30 seconds and the sound was quiet and distorted - as if there really is a dodgy connection somewhere. I tried disconnecting and reattaching etc, but the sound never came back (but my dash says Disc 1 Track 1 (which it never did before)).
I checked the GM10AUX and it's connections are all tight and look good - I realize it's a really vague problem but has anyone ever heard of this issue? Other than the CD changer tub area (where the GM10 PIE connector connects), is there anywhere else I could check for dodgy connections?
Also - could it be somehting to do with "let the vette sit overnight"? Is there some sort of memory / charge involved with that statement?
Thanks for any assistance!
To PIE Auxiliary Input Connector, GM10-AUX Problem
