Sponsored by: Innova
Capacitors?
Old Nov 17, 2008 | 07:22 PM
weinerschizel's Avatar
weinerschizel
Default Capacitors?
I have a 99 FRC with a pretty respectable stereo setup. Nothing crazy too crazy but enough to affect my lighting.
I'm thinking about purchasing one of those capacitors to put inline with the amps. Who makes a decent one at a decent price? Circuit city wanted $100 for theirs.
Thanks!
Old Nov 17, 2008 | 08:24 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
skip the capacitor and do the big3 first, will prly handle all ur issues
what amps u got
Old Nov 17, 2008 | 09:06 PM
weinerschizel
what amps u got
Cars parked and stored in a different state right now I'm not sure w/o looking at it what exactly the setup is. The guy I bought it from put it all together.
What's the "big3"?
Old Nov 18, 2008 | 02:09 PM
Gideon's_Test's Avatar
Gideon's_Test
The Big 3 involves upgrading the:
1) hot wire from battery to alternator
2) ground wire battery to alternator
3) ground wire battery to frame
The C5 faq will have better info on this..
Old Nov 18, 2008 | 02:36 PM
weinerschizel
I cannot find that faq... where is it?
Thanks!
Old Nov 18, 2008 | 03:00 PM
andrewjhaley's Avatar
andrewjhaley
I am no authority on this so do a little research, here is my advice
Use fairly large gauge wire if you do the BIG 3 - I would use the same gauge wire you use to power and ground your amplifiers in addition to the factory wiring that is in place as electricity will follow the path of least resistance. If you are pushing a lot of current then I would +1 the gauge of your ground wire in 2 and 3 below in addition to factory grounds in place.
1) same, should be fused for the gauge wire you use
2) ground from engine to chassis, in C5 a typical location would be a alternator bracket bolt, to chassis bolt in engine bay. There are some located near the hood struts close.
3)same
I would do the big 3 first as it would cost less than your proposed cost to add a capacitor.
Old Nov 18, 2008 | 03:13 PM
Gideon's_Test
http://forums.corvetteforum.com/audi...audio-faq.html
Old Nov 18, 2008 | 04:02 PM
pentavolvo's Avatar
pentavolvo
use 4ga
To Capacitors?
