Sponsored by: Innova
upgrading C6 stereo with factory cd changer Help pls
Old Nov 20, 2008 | 05:43 PM
kleiner3956's Avatar
kleiner3956
Default upgrading C6 stereo with factory cd changer Help pls
Ive read the faqs on C6 stereo install but still have couple questions i need to clarify. Any help would be greatly appreciated
Heres my plan, keep stock cd changer, add aftermarket amp, throw the bose amp in trash were it should have been in first place.
Replace all factory speakers, put 6.5 inch component in doors and 5.25 speakers in rear. Disconnecting center speaker
1. Is the only way to put in the aftermarket amp the PAC ADD-GM24 harness? Can i use the factory wires going to the bose amp since its being replaced completly anyway?
2. Will a three way 5.25 component set fit in the doors? or am i stuck with two way 6.5? Ive found door mounting plates for the 6.5 but no others so far
3. Is the digital alpine amp the only one known to fit in the cubby hole spot? I still want to be able to put top in hatch is there another spot for amp to go?
4. Ive always had subs with stereo set up, am i going to be disappointed getting rid of the cheap low 10inch bose in the door for the 6.5's?
Old Nov 21, 2008 | 01:03 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ill post later on when i have more time
Old Nov 21, 2008 | 06:37 PM
pentavolvo's Avatar
pentavolvo
you can tap at amp if u want or behidn radio its all the same no need for harness if u dont want to use it. IMO I highly recommend using the sven4 as some cars will generate noise etc and this eliminates all of that and gives u some level adjustments
The GMAA2 is totally plug and play at behind the radio and eliminates the need to splice at all
http://cgi.ebay.com/ebaymotors/Perip...fAudioQ5fVideo
3 way set should fit prly be kinda tight but should be doable, worst case cut the fiberglass a bit
some will put amps on the shelf right behind the seats as it doesnt interfere with top, some amps can be squeazed onto the back wall, otherwise cubby it is unless u just mount it where in the trunk. Arc Mini would also fit prly
ive done 130 dollar 6.5" components in the doors and had similar bass output over the bose 10" sub
Old Nov 21, 2008 | 08:11 PM
kleiner3956
which do you recommend most the sven4 or the gmaa2?
ive read about gm harnesses that produce a nasty eq curve is that true with the gmaa2?
Old Nov 21, 2008 | 08:22 PM
pentavolvo's Avatar
pentavolvo
nastay eq curve comes from the pac box, its not the harnes its all in the box
we found out we dont need box but some cars will get alt whine and its a bear to get rid of as the box does some isolation
the sven4 is a universal piece has no eq issues at all but has the filters in place to prevent noise etc. the gmaa2 is a harness and the sven4 sold as one piece making it plug and play
To upgrading C6 stereo with factory cd changer Help pls
