Sponsored by: Innova
Help with Amp install on C6Z06
Old Nov 21, 2008 | 06:32 PM
355Spider's Avatar
355Spider
Default Help with Amp install on C6Z06
I'm installing a JL Audio 250X1 with a JL sub and stealth enclosure. I need a line out to the low level RCA converter. I tried the rear speakers but the sound was very low. I thought about the amp in the footwell but I don't have a diagram of the wires. I was thinking about tapping off the subs in the doors. Any ideas?
Old Nov 21, 2008 | 06:34 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
READ THE C6 FAQ this is all addressed
low level converter isnt the answer
Old Nov 21, 2008 | 08:57 PM
HANNY's Avatar
HANNY
http://forums.corvetteforum.com/audi...-pin-outs.html
heres where i got info at. pretty easy to do,,,i tapped into the wires going into the amp in the footwell. Take your time and solder them in pretty easy really. regards,paul
Old Nov 22, 2008 | 09:18 AM
355Spider's Avatar
355Spider
Thanks guys. I wasn't sure if that pciture was a Bose Pin setup. I'm looking at that pic and this other thread which seem to contradict each other. Is that pic all low level inputs? Here's the other thread.
http://forums.corvetteforum.com/audi...ml?forum_id=20
Old Nov 22, 2008 | 09:43 PM
HANNY's Avatar
HANNY
the other post talks about the low level inputs to the amp being taped together. Thats what they are on the stock c6 as well so just follow that wiring scenerio and you are good to go
Old Nov 24, 2008 | 09:33 AM
355Spider's Avatar
355Spider
Got it but have a problem. I used the 8 pin connector's wires which worked great, until I drove the car then no sound. Maybe something came loose. We'll see. But it sound great.
Old Nov 24, 2008 | 09:43 AM
pentavolvo's Avatar
pentavolvo
what are u using for an amp turn on
Old Nov 24, 2008 | 12:10 PM
355Spider's Avatar
355Spider
One of the fuses. can't remember which one. The amp is on there's just no sound so I assume there's just no signal.
Old Nov 24, 2008 | 12:43 PM
pentavolvo's Avatar
pentavolvo
i agree, thats weird i wonder why u would loose signal like that loose something somewhere i guess
u sure the amp isnt going into protect
Old Nov 24, 2008 | 12:56 PM
355Spider's Avatar
355Spider
Yeah it looks fine. The protect light isn't lit up.
Old Nov 24, 2008 | 01:18 PM
pentavolvo's Avatar
pentavolvo
did u tap the low level inputs to the amp, or the outputs
Old Nov 24, 2008 | 03:38 PM
355Spider's Avatar
355Spider
I used the 8 pin connector which I think is the low level inputs.
To Help with Amp install on C6Z06
