Sponsored by: Innova
Build My Dad an Audio System:
Old Nov 24, 2008 | 08:40 PM
91LSMAN's Avatar
91LSMAN
Default Build My Dad an Audio System:
Dad wants to replace the Audio system in his 98.
Needs to be cost effective.
Needs to Sound good.
Replace the deck.
Replace the speakers.
(No Subwoofer. If an amp is necessary to power the speakers that is ok)
He doesn't need Nav, DVD or anything special, just needs to be able to place CDs and the radio.
Old Nov 24, 2008 | 08:52 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
rought budget, any other requirments... i got a whole setup in mind already i think
i highly recommend adding an amp, unless he doesnt really plan on turning it up loud
also u most likely will loose a little bit of bass
with all that said u can replace radio, keep ur stock speakers and bose subs while bypassing the bose signal processor which is prly why ur speakers dont work if i recall u made a post or osmething regarding this
Old Nov 24, 2008 | 08:56 PM
91LSMAN's Avatar
91LSMAN
He has not priced much of anything yet, just kind of threw this in my lap.
Lets say $500-$800? (Again, he wants to listen to CDs and the radio and it has to sound good.) If he has to spend more, I'll tell him that.
Deck and speakers, Amp only if necessary.
(I love car forums LOL)
Old Nov 24, 2008 | 09:02 PM
pentavolvo's Avatar
pentavolvo
u could try without the amp but IMO i would just put the amp in and get it done will sound alot better
can be done for under 600, ill post more specifics later tonite
Old Nov 24, 2008 | 10:16 PM
91LSMAN's Avatar
91LSMAN
That also sounds like an option. He likes bass, just not enough to want to add large subs with an aftermarket system. If he could get away with just replacing the deck and it sounded good, he would do that in a heartbeat.
You are correct. I started a thread last week about how the sound in his vette suddenly changed. I guess he could just replace the deck and see if he likes the way it sounds. We need to find an audio shop that has already done this in a vette so we don't have to tell them how to do their jobs.
Thanks for your help.
Old Nov 24, 2008 | 10:38 PM
pentavolvo's Avatar
pentavolvo
how comfortable are u doing some basic wiring, honestly just a desk swap isnt a horriable job at all.
personally i think u need to pull deck out and test some of the pinouts to verify all 4 speakers less the bose subs are good still. woudlnt be too hard if interested i can get u the info
Old Nov 25, 2008 | 01:31 AM
91LSMAN's Avatar
91LSMAN
I really don't have the right equipment to test speakers. I think I'll leave this to the "pros."
I told him that he should take the opportunity to do the deck and speakers, who knows-he could replace the deck and the speakers die soon afterwards.
Old Nov 25, 2008 | 12:46 PM
pentavolvo's Avatar
pentavolvo
its actually quite simple and u really dont need anything fancy
my concern is that without the bose subs he will feel like he has lost too much bass
Old Nov 25, 2008 | 03:33 PM
91LSMAN's Avatar
91LSMAN
I understand.
I think what you posted earlier....
...might be the best option.
Old Nov 25, 2008 | 03:34 PM
pentavolvo's Avatar
pentavolvo
i think that would be a great option as well which is why i mentioned pulling radio and testing to make sure all the speakers are getting a signal still. it literaly invoves taking 2 pieces of wires sticking them into one of the pins on the harness and hooking to a AA battery to see if the speaker pops
Old Nov 25, 2008 | 03:41 PM
91LSMAN's Avatar
91LSMAN
The speakers are getting a signal, it just sounds bad. Thanks for all the info.
Old Nov 25, 2008 | 03:43 PM
pentavolvo's Avatar
pentavolvo
so u get sound on the speakers it just sounds horriable?
i wonder if they arent blown
Old Nov 25, 2008 | 05:36 PM
Fasthotrod's Avatar
Fasthotrod
Exactly what I was thinking, PV.
I would play the music and just use balance/fade adjust to play each speaker by itself. If it's just one speaker, then it's probably blown. He could swap left/right side to see if the problem follows the speaker or not.
Follows speaker = blown speaker.
Stays on that side = bad radio/amp.
Replacing the stock Bose speakers with stock speakers is an option. You can probably find replacements on the Forum easily enough. I would upgrade the 3.5" drivers at that time, too... it's a cheap & easy upgrade.
If you want to totally upgrade, do a deck, speakers and an amp as a minimum. (Ditch the rear speakers completely, or just keep the stockers.) Dampen the doors with dampening material and sound absorption material for added bass response and a more quiet cabin.
Good luck.
Mark
Old Nov 25, 2008 | 08:47 PM
91LSMAN's Avatar
91LSMAN
Good luck.
Mark
Yes, all four speakers work, they just sound bad.
I have used the balance/fade function-I did that this weekend. All four sound bad. That is why I assumed the speakers were good. It would be strange for all 4 speakers to go bad at the same time, so I assumed the deck went bad, not knowing there is another part that was mentioned earlier in this thread.
Thanks for all the help and suggestions-keep it comin!!
Old Nov 28, 2008 | 01:49 AM
pentavolvo's Avatar
pentavolvo
so did u want to do 4 speakers and new radio, or 4 speakers amp and new radio
Old Nov 28, 2008 | 10:32 AM
91LSMAN's Avatar
91LSMAN
It depends on how much an amp adds to the cost.
I told him that if he goes with just speakers and a deck he could loose bass, so he said that he might consider getting a sub as well. He is actually going to go to a stero shop or two today to see if there are any specials.
Old Nov 29, 2008 | 10:49 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Listen to pentavolvo! He pointed me in the right direction and is still helping me, an asset to the forum!
To Build My Dad an Audio System:
Old Nov 29, 2008 | 11:49 PM
pentavolvo's Avatar
pentavolvo
my recommendation is a radio prly a basic alpine, 4 channel amp, component speakers up front, coaxials in the rear
ill pull up some models
Old Nov 30, 2008 | 12:20 AM
pentavolvo's Avatar
pentavolvo
do an ebay search for these model numbers or search crutchfield
alpine cde-9874 radio
pioneer gm-6300f amp
polk speakers
coaxials for rear db651 (coupe) or db521 (zo6, frc, vert)
fronts either db651s if powering from a radio or step up to db6501 components if using amp
IMO get 2 pairs of the polk db651s and the alpine radio wire it all up and u might be good, if he needs more bass pick up a bazooka bass tube
Old Nov 30, 2008 | 01:29 AM
91LSMAN's Avatar
91LSMAN
polk speakers
Thanks-I'll pass the info to dad. He is still undecided as to what he really wants to do.
