Sponsored by: Innova
No talk radio
Old Dec 3, 2008 | 08:41 AM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default No talk radio
I have a Kenwood 7019 unit which is really nice but the am doesn't work. A couple shops have told me that the original Bose amp boosted the am signal and that the Kenwood doesn't. No one has a solution yet.
Any help for a '04 C5 coupe ? I gutted the entire Bose system and run a Audison amp.
Old Dec 3, 2008 | 09:33 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i can dig it up for u later but its deff in C5 FAQ i believe, u gotta wire up the OEM antenna booster so it turns on and it shoudl fix ur reception issues
Old Dec 3, 2008 | 10:04 AM
techristian's Avatar
techristian
I have a similar problem with my Jensen. Weak windshield antenna seems to be the culprit.
Dan
Old Dec 3, 2008 | 10:06 AM
Kale's Avatar
Kale
I can't believe there isn't a quick plug and play for this issue.
Old Dec 3, 2008 | 11:18 AM
pentavolvo's Avatar
pentavolvo
ill pull up the info, the problem is there are 2 wires for OEM antenna booster a 12 volt which everyoen is hooking up generally behidn headunit then a 5volt trigger which u need to wire up as well
Old Dec 3, 2008 | 04:22 PM
pentavolvo's Avatar
pentavolvo
http://forums.corvetteforum.com/audi...ml?forum_id=20
Old Dec 3, 2008 | 07:14 PM
worldtraveler
Great, thanks. I'll have to try this when I get home.
Old Dec 4, 2008 | 12:32 PM
techristian
3 questions
1) If it is a 5V signal that turns on the antenna booster, is the 12V now coming from my Jensen radio, doing harm to the logic ? (5V is logic 1 and 0V is logic 0)
2) Am I misunderstanding , or does the drivers seat need to be removed to get at this antenna module?
3) Could a simple resistor from the pink wire in series be used to create the 5V logic 1 ? Normally with computer chips any voltage between 3.5V and 5V are logic 1 (ON).
Dan
http://teachmedrums.com
Old Dec 4, 2008 | 12:43 PM
pentavolvo's Avatar
pentavolvo
there are 2 wires a 12volt and a 5volt that both need to be enabled. you are powering up the 12volt, the 5volt is a totally seperate wire
you can do this behind dash or at the actual module on side of panel next to drivers seat
no removal of driver seat is necessary as im a small guy but would prly make it much esaier for others
as far as using a resistor you would need to nkow the current draw of the unit to accurately pick a resistor. IMO using the IC voltage regulator
To No talk radio
