Hey everyone im about to add a sub amp and replace the 3.5 with dif speakers. I want to make sure i have everthing the installer will need so i can hopefull get this done in one day.
So here is a list of things i think are needed to add the sub and amp to the factory nav.
GMAA2= Is this a plug and play or will the installer need to cut wires to hook this up??
Iwas told i need this part but im not sure for what?? Its a
peripheral line output converter 50w output
what is this for is it needed??
And for the 3.5 replacements all i need is the
gm dw 4568sh speaker wire
right??
Ok thanks for any help and info. Please tell me if i need anything else that i might have missd??Thanks to everyone that has been giving me info so far
ok cool thanks , i just want to thank you again for all your info i dont think i would have found out about the parts i need to get this done I also have a slight rattle on my pass door it only comes on when bass hit really hard it sounds like its down by the bass speaker area. Any ideas on how to fix it?? im think of putting a little dyno mat in some place??
It is probably the bose emblem on the grille. Most people remove it.
No, No, No,- it's like the warning tag on a mattress, it's against the law to remove any Bose tags lest anyone think that they are not listening to a "premium" sound system.
did you take out the stock amp? its not that big but saw where someone put one there thats one place, also behind the passenger seat or i am going in the RR cubby for now but may move it behind the seat. Hell as much room is behind the rear fender (behind the tailights) maybe there ,,,,lol. paul
lol good idea, No im just adding one amp for the sub i was also thinkin behinde the passenger seat. Should i drill it in or???
Hey everyone my said i really dont need to use the GMAA2, said that you only get funny sounds if its not done right but he is sure they know how is this right or should i just get this piece??
