Sponsored by: Innova
HELP.bose change out
Old Dec 29, 2008 | 12:31 PM
93c4dad's Avatar
93c4dad
Default HELP.bose change out
Taking out the bose system on my 92.cannot fine the amp.i looked in back of the seat area.and under the dash.still no luck.i am just looking for the antenna hookup.and to unhook power to amp.
Old Dec 30, 2008 | 01:22 AM
c5blkvetteguy's Avatar
c5blkvetteguy
The amps are with the speakers.
Old Dec 30, 2008 | 09:18 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If your car has an air bag on the pass side, then it is in the cubbie behind the pass seat. If you do not have an air bag there, then it is under the dash on the pass side. To see the antenna lead, first remove the hush panel on the pass side, and then remove the air vent in the dash. If you look thur the opening, you will see a silver box, the antenna lead should be on the left side, in the front. Remember that you will need an adapter for the lead.
Randy
Old Dec 30, 2008 | 12:36 PM
93c4dad's Avatar
93c4dad
Found it.
To HELP.bose change out
