Sponsored by: Innova
PAC Steering Wheel interface question
Old Jan 18, 2009 | 07:19 PM
EggrollXpress61's Avatar
EggrollXpress61
Default PAC Steering Wheel interface question
Hey guys, i hooked up the SWI-PS interface from PAC but cant seem to get it to work? I know i grounded it and the power right, so Im guessing its the green wire.
What do I do with it? I used a tap in squeeze connector to tap into the blue wire behind the factory wire harness in spot A7.
The instructions say "Connect the SWI-PS 's Green wire to pin # A7 (blue) of the above connector. Connect pin # A6 (purple) to accessory +12v"
Am I not connecting it wrong? or am I not supposed to just tap into it? and also how do I connect pin A6 "purple to accessory +12v?
Old Jan 20, 2009 | 01:03 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u need the accessory 12volt hooked up, tie it in to the acessory lead at ur radio
