I have a pair of Diamond Audio D6 amplifiers in excellent condition. One is a D6300.4 4 channel, and the other is a D61000.1. They are both the same size so the install looks great. They work great, been used very little, although they are still installed at this time. I will pull them out to put my JBL Crown's in ASAP. If you are interested let me know, I'll take $500 for the pair shipped in the 48 states. Pics can be provided.
Chris
Could I use this amp just for the front 2 speakers and 1 sub? Sorry about the amateur questions, I do not know a lot about audio. Also, what level quality is this? I am used to MTX in my old car.
You could use the four channel to do that, would have to be smaller sub, like 200 to 300 watt sub for proper power. The quality of these amps is excellent at least as good as MTX, not to knock MTX in any way, they are great amps as well. What speakers are you planning to power?
Starting to build my system. Dont have a lot of money. I have a 12inch sub already. Thinking like MB Quartz 6.5s up front. Nothing special. You can get into 10 of thousands which I am not doing..
If it is a KFC-W112S, then the amp could play it. You will need a box that is between 1.0 cu. Ft. and 1.5 Cu. Ft. Bigger the better. I am not sure on a C6, but 1.5 is close to the entire cargo well if you use MDF to build the box. You can still easily get the top in with that size box. The KFC-W112S is rated at 200W RMS, 800W Peak. The D6300.4 will produce 150 watts RMS by bridging 2 channels to the sub. Should work pretty good. Let me know if you are interested, I can send you the owners manual and pics via email.
Chris
