Sponsored by: Innova
Speaker Sizes for 95 C4?
Old Feb 18, 2009 | 08:46 PM
-=Tom=-'s Avatar
-=Tom=-
Default Speaker Sizes for 95 C4?
Hey guys I've poured over thread after thread and read the stickied FAQ but can't seem to find a straight answer on what speaker sizes will fit in my 95 with the Bose Gold? I've decided to upgrade the head unit and want to replace all 4 speakers with aftermarket speakers. I'm guessing I'm going to have to butcher the Bose enclosures to get aftermarket speakers in there but what sizes should I be buying?
Right now I'm thinking that 4" speakers up front and 6.5" speakers should go in the rear.
Can I go larger to 6.5 in front and 6x9 in the rear and should I?
Thanks in advance for any advice.
Old Feb 18, 2009 | 08:59 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ok in the back totally ditch the bose enclosure and a 6x9 will bolt right in
upfront its up to you u can either keep the bose box and go with a 4" i believe or rip the bose box out and go to a 5.25 or 6.5 with a mounting plate
Old Feb 18, 2009 | 09:41 PM
-=Jeff=-'s Avatar
-=Jeff=-
Actually with eht e bose plates in back a 6.5" will fit
you can get a set of brackets from a 89-older that will house a 6x9 or get the speakr mounts from a NON-bose car..
6x9 in back and 4x6 in front
Old Feb 18, 2009 | 09:42 PM
-=Tom=-'s Avatar
-=Tom=-
Thank you very much! I would like to do as little farting around as possible so are you saying I could fit a 4" right into the front Bose enclosures without modifying them to fit? If that's the case then that's what I want to do. If I have to modify it to get the 4" to fit then I might as well go to the 6.5" and a mounting plate.
I didn't know I could just remove the rear enclosures and fit 6x9s in there without any enclosure at all. That's great to hear.
Old Feb 18, 2009 | 09:46 PM
pentavolvo's Avatar
pentavolvo
honestly im not 100% positive if u can direct bolt a 4" or not im 99% positive u can
also fyi u will need to run new wiring into the doors and to the back
Old Feb 19, 2009 | 08:54 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I am selling the Eclipse HU and Infinity speakers out of my car, send me a PM if interested, or check out the for sale section. Also thinking of selling my Vrum Vrum faceplate.
Randy
Old Mar 7, 2009 | 09:26 PM
samsonb's Avatar
samsonb
So, what is the best size for the rear, 6.5 or 6x9?
I bought this 6.5 adaptor plate for the rear bose on my 89:
http://cgi.ebay.com/6-Rear-Speaker-A...d=p4634.c0.m14
Though, with the bose housing removed, I can mount 6x9 speakers.
There isn't alot of room, anyone know of which speakers fit? I'm guessing they would need to be low profile.
Old Mar 8, 2009 | 04:25 PM
RandyJ75's Avatar
RandyJ75
I am putting 8" subs in my rear compartments, so I'm sure just about any speaker will fit.
Old Mar 8, 2009 | 07:58 PM
samsonb's Avatar
samsonb
Ok, I guess I'll listen to both 6.5" and 6x9 and pick which ones sound best.
To Speaker Sizes for 95 C4?
