Sponsored by: Innova
C6 Radio Schematics - Click Here!
Old Feb 22, 2009 | 04:25 PM
markcz's Avatar
markcz
Default C6 Radio Schematics & Plug Pin-Outs ***Click Here!***
10/25/19 edit: New link to prints here....
https://photos.app.goo.gl/1tfBrWo46y9vKdQF7
Radio Schematics & Plug Pin-Outs available here.
Since Photobucket is free, after clicking on the links I would strongly recommend you right click and 'save as' on each pic that you might want to have available in the future.
="5"%SCHEMATICS:
1 of 10 radio/power (US8 & U66)
2 of 10 speakers (U66)
3 of 10 radio/power (U65)
4 of 10 speakers (U65)
5 of 10 antenna
6 of 10 XM receiver
7 of 10 steering wheel controls (without Blue Tooth)
11 of 10 steering wheel controls (with Blue Tooth)
8 of 10 Nav
9 of 10 OnStar
10 of 10 OnStar Audio
="5"%PLUG PIN-OUTS:
1 OF 15 Amp
2 OF 15 Amp
3 OF 15 Amp
4 OF 15 Amp & XM
5 OF 15 Mic & Radio C1
6 OF 15 Radio C1, C2, C3
7 OF 15 Radio C3, C5 & Antenna
8 OF 15 Antenna & Speakers
9 OF 15 Speakers
10 OF 15 Speakers
11 OF 15 Speakers
12 OF 15 Speakers
13 OF 15 Speakers & VCIM C1 (OnStar)
14 OF 15 VCIM C1, C2, C3
15 OF 15 VCIM C4
Old Feb 22, 2009 | 09:24 PM
decappa's Avatar
decappa
Thank you so much! I was looking for these recently.
Old Mar 21, 2009 | 04:57 PM
markcz's Avatar
markcz
Default ttt
Plug Pin-Outs added today.
Old Jun 9, 2009 | 03:08 PM
95blklsc's Avatar
95blklsc
Great! Thanks, I just saved all of them for future use!
Old Apr 2, 2010 | 10:40 PM
LS WON's Avatar
LS WON
SCHEMATICS:
5 of 10 antenna
6 of 10 XM receiver
8 of 10 Nav
9 of 10 OnStar
PLUG PIN-OUTS:
1 OF 15 Amp
2 OF 15 Amp
3 OF 15 Amp
4 OF 15 Amp & XM
9 OF 15 Speakers
10 OF 15 Speakers
11 OF 15 Speakers
12 OF 15 Speakers
15 OF 15 VCIM C4
Old Apr 3, 2010 | 12:35 AM
markcz's Avatar
markcz
Originally Posted by LS WON
Old Apr 3, 2010 | 12:46 AM
LS WON's Avatar
LS WON
Just wanted to know what brand that stereo system is.
Old Apr 3, 2010 | 01:26 AM
markcz's Avatar
markcz
Would you care to exlain why you need to know the BRAND of the components. If you have a question about how/why it does what it does, just ask
Old Apr 3, 2010 | 04:39 PM
LS WON's Avatar
LS WON
I don't need no explanation as to why I just want to know the brand.
Do you need to explain why you want a Corvette? I sure don't. Maybe you do to your wife or so
Old Apr 3, 2010 | 04:47 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
what does it matter, the components are garbage, a set of jensens from walmart will prly sound better
Old Apr 3, 2010 | 11:27 PM
LS WON's Avatar
LS WON
No Audiovox is better.
Old Apr 16, 2010 | 10:30 AM
markcz's Avatar
markcz
Default bluetooth buttons and SWI controls
I just added the schematic for late model C6 with the bluetooth buttons on the steering wheel.
The BT buttons are wired in series with the normal radio control buttons on the other side, so if you install an aftermarket Steering Wheel Interface control box for a new HU, I would guess that you now have 7 buttons to program with the SWI. The oem BT buttons still won't control any bluetooth functions on the new HU, but you will get a few extra audio control buttons from them. You just need to determine which of the available SWI functions you use (look at the SWI programming instructions, you'll see what I mean).
Old Apr 16, 2010 | 11:42 AM
pentavolvo's Avatar
pentavolvo
thanks... very nice
Old Dec 20, 2012 | 03:31 AM
Slammin07's Avatar
Slammin07
Would anyone be able to point out the pin out diagram which would reflect the back an 07 bose & navigation head unit? Also, would anyone happen to know where I could locate the wires ran from the factory microphone in the a pillar?
Old Dec 20, 2012 | 05:55 AM
Fasthotrod's Avatar
Fasthotrod
I believe that the Bose seven speaker premium sound system is RPO code U65.
As for the radio plug, which one are you taking about? The main plug is C1. C2 is for amp mute, vss, and XM/aux input. C3 is for communications with the vehicle bus. C5 is for the microphone.
I might be missing some things, as I'm posting from my phone... but that should point you in the right direction.
Old Dec 20, 2012 | 06:08 AM
markcz's Avatar
markcz
The prints in my original post were scanned from an '07 manual
To find specific wires look at numbers on schematics and pinouts at same time, you'll figure out their system eventually.
Old Dec 20, 2012 | 06:41 AM
Slammin07's Avatar
Slammin07
Lol got it! Yeah it definitely took me a minute to decipher all of that. But from the way it looks, the main plug (c1 on the radio side) doesn't have a dimmer/illumination control. I'm wiring an AVIC-X930BT to install tomorrow and I'd like the dimmer option to be functional. What does everyone use for this?
To C6 Radio Schematics - Click Here!
Old Dec 20, 2012 | 04:53 PM
markcz's Avatar
markcz
Under the TC/AH button on the console use the grey wire w/black stripe
Old May 15, 2013 | 03:42 PM
Haw's Avatar
Haw
1st Gear
Hi,
thanks for this worthful information,
i am from Germany and there are such informations rare.
I installed a alpine W920 in my Corvette C6 (year 2009 and Bose 7 speaker sound system) using a Pac adapter. Replacing the 3,5 inch Speakers in door
Now i have a hum in the system-- any recommendations on that.
I am reflecting to replace the amp therefore i want to purchase male connectors C1 and C2 wiring ownself.
I am just wondering if for the 10 inch subs i have to use a low or high level input ( i assume the subs have their own amps) can you help me
any recommendations on the amp fitting in original space area
Thanks in advance
Harro
Old May 17, 2013 | 08:43 PM
markcz's Avatar
markcz
Stock radio sends line-level signal to amp, amp then splits low freq to door subs, subs have internal amps.
EDIT: This is only true for the 7-speaker setup, on 9-speaker cars the subs are powered from the same amp as all the rest.
