Sponsored by: Innova
C5 / Adding an amp Question
Old Feb 26, 2009 | 11:23 PM
sandman0125's Avatar
sandman0125
Default C5 / Adding an amp Question
I am adding an amp to my system. I bought an inverter or diverter whatever they are called. The kind I bought you tie into your rear speaker wires behind the head unit which then converts to RCA's. Is this possible with the factory system. If so, is there a schematic which tells me which wires on the plugs are the rear speaker wires. The info I have got on the remote wire is telling me to run it to the fuse box. Please help, Thanks
Old Feb 26, 2009 | 11:46 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
fuse box is not correct
READ THE C5 FAQ
and rear speakers is a no go that adapter u bought will not help you
