Sponsored by: Innova
View Poll Results: Speaker upgrade - use center speaker (not OEM)?
Yes, put new speaker there and connect to 8120
42.86%
No, it has no use and will mess up your front sound stage
57.14%
Voters: 7. You may not vote on this poll
Center Speaker poll - speaker upgrade
Old Mar 5, 2009 | 08:25 PM
ilovemyredhotc6's Avatar
ilovemyredhotc6
So. Cal. Events Coordinator
Default Center Speaker poll - speaker upgrade
I'm installing a Kenwood DNX8120 in the vehicle with the HAT Clarus 61-2 for the front stage and removing the rears completely. I'm planning on using aftermarket amps for the system (Alpine PDX 1.600 for the sub, not sure about amp for components - open to suggestions). I'm looking for advice regarding the center speaker. If you have any thoughts, to include the best way to connect it to the 8120 if you think I should use the center speaker, please post them here. Thanks in advance.
Last edited by ilovemyredhotc6; Mar 5, 2009 at 10:00 PM. Reason: Typos - fixed info
Old Mar 5, 2009 | 09:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
is this about the center speaker or rears im confused
ditch the center all together
are u using aftermarket amps
we need more info
Old Mar 5, 2009 | 09:55 PM
Louie Detroit's Avatar
Louie Detroit
From: Democrat Sh*thole of Detroit. Nov 8th, 2016 - The day America was saved... Blue Lives Matter
St. Jude Donor '11-'12-'13-'14
I'm with Greg - your post is confusing - please fix it.
Old Mar 6, 2009 | 09:33 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Ditch the dash speaker. Calling it a center gives it more credence than it deserves, it's garbage in the stock system and will completely screw your soundstage in a good setup unless you're planning on a 5.1 Dolby Digital discrete channel, which to my mind isn't worth doing in this car.
Old Mar 8, 2009 | 01:55 PM
Helijason's Avatar
Helijason
x nay the center eh! Call me when it's movie time!
To Center Speaker poll - speaker upgrade
