Sponsored by: Innova
C6 door woofer question ?
Old Mar 9, 2009 | 04:54 PM
dachy's Avatar
dachy
Default C6 door woofer question ?
Can someone confirm these numbers for 2005 C6 non Bose :
8" woofer in non Bose
10" in Bose
All I could find in searched archives were posts were 10" Bose system was mentioned
I already replaced fronts 3.5" and rears 5.25" speakers, but the real problem I have is with the driver side woofer, it's probably blown .. making strange noise.
Thnx in advance!
Old Mar 9, 2009 | 04:55 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Originally Posted by dachy
Can someone confirm these numbers :
10" in Bose
Thnx in advance!
Yes, self-powered 10" in the Bose system, 8" powered by the Delco amp in the non-Bose system.
Old Mar 9, 2009 | 05:14 PM
dachy's Avatar
dachy
Thank you very very much !!!
Would you happen to know the max depth of this 8" ?
Old Mar 10, 2009 | 07:40 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You've got a good 3.5" of mounting depth there. But if you're thinking of putting a real sub in then think long & hard about that. You'd need to run a separate amp as the stock amp doesn't put enough power out for even the least power hungry aftermarket sub. Additionally doors make for lousy sub enclosures.
Old Mar 10, 2009 | 09:09 AM
John LMBZ06's Avatar
John LMBZ06
Are you happy with the results of changing out the 3.5" and 5.25" speakers? I am thinking of doing that also. I have the Bose system and turn the bass down below the 1/2 mark, so I don't think I need to mess with that.
Old Mar 10, 2009 | 01:13 PM
dachy's Avatar
dachy
Yest I am happy, it's the least expensive way to improve the sound in our cars.
I followed this thread posted by "TheKomoman" and his advise really helped me decided: http://forums.corvetteforum.com/1562485130-post2.html
If you don't want to spend too much money, it's worth a try. Most members here went with Eclipse SE8233 and Eclipse SE8353
I have one more question to "TheKomoman" ... can you please advise of which 8" speaker / woofer to use ? I don't want to use any "power hungry" sub as you mentioned, but I have to change my 8" due to it's damage and I don't know which 8" speaker to buy .. 1-way, 2-way ? what frequency response ? etc.
Your help is greatly appreciated !! Thnx !!
Old Mar 10, 2009 | 01:17 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Honestly I have no idea because my level of interest in what the stock speakers are is nil! You might want to post a WTB thread and see if you can pick up a stock 8" cheap from someone that replaced their system. I don't think you'll get a dramatic improvement of any sort using an aftermarket speaker so I'd try a stock replacement.
Old Mar 10, 2009 | 01:28 PM
dachy's Avatar
dachy
Good idea .. I'll try to get a stock 8"
Thanks again !!
Old Mar 11, 2009 | 06:52 PM
John LMBZ06
By the way, the signal being sent to the 8" is just a low frequency, so it would not help to use a two way or three way.
To C6 door woofer question ?
