Sponsored by: Innova
No dimmer control - DNX5120
Old Mar 10, 2009 | 08:38 PM
vettfvr's Avatar
vettfvr
Default No dimmer control - DNX5120
Got the DNX5120 installed this weekend!! Everything is working beautifully. Only problem is no dimmer function. I have it properly programmed, I assume I haven't properly wired it. Where do I locate the factory dimmer wire (Gray) on my 96 CE. Do I need to worry about the SYS light? Thanks.
Old Mar 11, 2009 | 08:30 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I don't know the C4 so I can't answer the question you posed, but for the ILL wire all you need is 12V that switches on when the lights come on. If you have any lighted buttons on the dash or console that only come on when the lights go on you can tie off to that and it will function as the ILL wire.
Old Mar 14, 2009 | 06:29 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i left my ILL button unconnected when i installed my 5120 last week.
what is the function of it? does it just make the screen darker when there are interior lights on? is it a useful feature to have?
Old Mar 14, 2009 | 06:48 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
It is what dims the unit when the lights are on so it's not blindingly bright inside the cabin at night. It's actually opposite what one might think - bright during the day, dim at night.
Old Mar 15, 2009 | 06:34 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i see. i might have to consider hooking mine up.
can you recommend an easy wire on a c5 to hook this up to?
---another edit:
i just found this old pic and info, would this climate wire work for my ILL wire?
Connect the illumination wire to the cream colored wire on the climate control harness. (optional). Solder and tape the connection. Once again I use an extra extension piece gray of wire, incase I needed to pull the HU out. That is why the wire connecting to the cream climate control wire is gray.
Old Mar 15, 2009 | 07:11 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
^^^ That wire does not work with illumination on 5120. Ask me how I know Leave it disconnected and use the unit feature for dimming etc.
Old Mar 15, 2009 | 07:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
thanks, N.
i kinda like the idea of automatic dimming when you turn on the parking/headlights tho.
do you know any easy access interior wire activates when you turn on the headlights?
Old Mar 15, 2009 | 08:23 PM
heavymetals's Avatar
heavymetals
I had a similar problem when I installed my N4 in my Z.
I ended up using a transistor and a few resistors to get it to work correctly.
Old Mar 15, 2009 | 08:28 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i have used this wire with a 5120 more then once and it dimmed just fine
Old Mar 15, 2009 | 09:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
hmm. i wonder why it didn't work with the big N's car. i'll give it a shot when i get back in there.
Old Mar 15, 2009 | 10:08 PM
pentavolvo's Avatar
pentavolvo
yeah thats weird no reason it shouldnt work
i will say this the wire does work but it may not be setup right in the radio u have to go into the dimmer settings, set it on sync i believe, and you should be able to set brightness, turn lights on, and set again, and they should swap between the 2 individual settings
Old Mar 16, 2009 | 07:00 PM
FactoryRaceCar
Tried all that. It worked weird. The brightness etc changed with the time of the headunit but not with that wire. I knew for a fact that wire works for dimming because I had 3 (boost, fuel pressure, air/fuel) gauges tied to that wire and they dimmed just fine.
BTW, I need to take some advice from you with the sound system I am doing to my new car. Using factory navigation, 2 amps, components, boxology with subwoofer, lockpick, rearview camera and iPod etc
Old Mar 16, 2009 | 08:01 PM
pentavolvo's Avatar
pentavolvo
curious how much more it would be for u to do to a dnx5120 or something similar vs the lockpick
Old Mar 18, 2009 | 11:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i hooked up my ILL wire to that cream colored wire on the HVAC and it works perfectly.
Nouman,
i believe the problem you had was that there is an option to have the illumination sync with the navi (which you said yours was timed with the headunit) or to sync with a switched wire. choosing to sync with that wire then adjusts the illumination when the lights are turned on.
Old Mar 19, 2009 | 09:55 AM
FactoryRaceCar
Nouman,
Good to know. I never even had time to go thru one full CD thru my headunit. I sold my car way before I ever got to enjoy it
Old Mar 19, 2009 | 09:57 AM
FactoryRaceCar
The ONLY reason I don't want to go with aftermarket unit is because I want to keep the Navigation function in HUD with the factory unit. Can you still get Nav in HUD with any other aftermarket (Garmin based) units? That would be awesome!
To No dimmer control - DNX5120
