Sponsored by: Innova
C5 sub/amp question
Old Mar 17, 2009 | 01:30 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Default C5 sub/amp question
I will be upgrading my stereo soon and have some newb questions.
I will be adding a sub to my C5. The sub will be an Alpine SWS-1243D dual 4ohm 12" in a stealth type box.
The sub is rated at 900 peak, 300RMS. I was looking at Elemental Designs for the amp, the nine.1 in particular.
The 9.1 is rated for 450x1 @ 4 ohm. Is this amp rated too much for this sub? (it seems so, but I'm no stereo expert)
The sub/box is a done deal. If this amp isn't a good idea for this sub, can anyone recommend a mono amp that would be a good fit?
Thanks.
Old Mar 17, 2009 | 09:49 AM
Fasthotrod's Avatar
Fasthotrod
A dual voice coil 4 ohm sub will be wired up as either a 2 ohm or an 8 ohm load. So you need an amp that can handle that impedance.
It's okay to hook up an 8 ohm load to an amp that is 4 ohm capable... as 'ohms' is the measure of the resistance to current flow. If you tried to use an amp that was rated at 8 ohms with a 2 ohm load, you would quickly burn it up.
That being said, the ED Nine.1 is rated at 450 watts @ 4 ohms, 900 watts @ 2 ohms, or 1,200 watts at 1 ohm. It will work fine for that sub... so long as you recognize that the amp is capable of delivering more power than the sub can handle.
This is not a bad thing, if you can recognize when the sub is at it's physical limits and don't push it past that point.
I would much rather have a really powerful amp and exercise "volume control" than have a weak amp and try to push it's limits.
You could go with a smaller amp if you wanted... and save a few bucks in the process. For example: This Kenwood amp can deliver 300 watts at 4 ohms, or 500 watts at 2 ohms. All for $130.
http://www.sonicelectronix.com/item_...KAC-8104D.html
Hope this helps.
Mark
Old Mar 17, 2009 | 09:56 AM
jdmvette's Avatar
jdmvette
Night Owl for life
thank you mark, it does help.
can you tell me how to wire up a DVC sub?
is it positive to one side and negative to the other side?
Old Mar 17, 2009 | 10:33 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
It's a little hard to explain, so here is a diagram of how to wire a single dual voice coil 4 ohm sub into 2 ohm or an 8 ohm load.
One 4 ohm Dual Voice Coil (DVC) Speaker
Option 1 (parallel) = 2 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Old Mar 17, 2009 | 11:52 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
nine1 is alotta amp, maybe get a dual 2 ohm sub or single 4 ohm and a nine2
Old Mar 17, 2009 | 12:47 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the alpine sub that is coming with the box is the sub i'll be using so i need to get an amp that works best with that one.
i'm just looking to add some thump to the system, so the stereo is going to be pretty basic.
Old Mar 17, 2009 | 12:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
thank you for post that diagram, it helps.
now i just have to figure out which amp to use.
To C5 sub/amp question
