Sponsored by: Innova
Stupid Questions?
Old Mar 18, 2009 | 06:20 PM
user051728's Avatar
user051728
Default Stupid Questions?
Got a few questions, might be dumb, but I've done a little searching and haven't found the answers.
If I wanted to swap the head unit for an Alpine IVA-W505/P1, can I KEEP the stock XM receiver, AM/FM Antenna, and Navigation Antenna? I'd hope those connectors are "standardized."
I know when I yanked my Chrysler Radio out, those all had a similar "single pin" antenna connector. I don't know if GM does the same thing.
I know to keep the stock amp (with OnStar) and chimes, and steering wheel controls I'd need the right "cables" from Peripheral Electronics.
Old Mar 19, 2009 | 08:10 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
The stock XM module will only talk to factory heads and while I suppose you could right the connector on the nav antenna it's so easy to run the nav antenna to the area where the dash speaker is I wouldn't bother. For the AM/FM you'll need an inexpensive, and very common, plug adapter.
