Sponsored by: Innova
stereo wiring
Old Mar 22, 2009 | 07:44 PM
jimish's Avatar
jimish
Default stereo wiring
I think I got my answer in the C% tech section, but hopefully someone can verify.
Can a c5 stereo, am/fm/cd, Bose amp, and front and rear speakers be tested on a bench?
I hooked up every wire except for...
orange wire from HU to DLC schematics in data link
green power antenna, supply voltage,ant relay
wires that go to the remote unit
Clock works, cd's eject, but no display or sound.
If all I can use in another car is the speakers, do I hook up 2 orange wires to 12v
2 black/white wires to ground
remaining two wires to stereo output?
Old Mar 22, 2009 | 09:09 PM
markcz's Avatar
markcz
That's what happens when the radio is off
I may be confusing C5 and C6, but here goes....
I don't think you can run it on a bench. The stock radio doesn't have a 'trigger' wire to turn it on like most radios do. The orange DLC wire that you don't have connected to anything normally "listens in" on the serial data communications line in the car. When the PCM sends a certain signal out over that serial data line the radio "hears it" and turns on until it gets the signal to turn off. The radio then has a +12V output that turns on the antenna and bose amps (the green wire you don't have connected to anything).
If the above quote is only concerning the 8" bass speakers, then yes, that sounds correct. However, as subs go they kinda suck.
The 3.5" and 6.5" (or 5.25" in a vert) speakers are just standard 4 ohm speakers so they can be used in any system with a low powered amp, but there's no kinda about it, they definitely suck.
You can find the C5 radio schematics by clicking on the 'my photos' link under my avatar. They might help you out a bit.
Old Mar 22, 2009 | 11:46 PM
jimish's Avatar
jimish
Thanks, thats the answer I didn't really want to hear.
So the HU and Bose amp only work in a c5 when connected through the computer. I'll post those on the for sale forum.
I am looking for a basic sound system. If I buy a aftermarket stereo, As long as I can hook it up to these speakers, I'm OK. Rear speakers are just two wires, LR+, LR-, RR+, RR-. Front speakers with the built in amps are 2 orange pos., 2 bl/wh neg. ground, I think yellow brown on one side and black grey on the other side go Rf+, and -, and LF+ and -.
At least I get to use something.
Old Mar 22, 2009 | 11:58 PM
markcz's Avatar
markcz
The front speakers aren't really one unit that splits one incoming signal. In the stock system each speaker gets it's own input. The 3.5's get the mid/high signal and the big ones get only the low bass signal. Only the big bass speakers are amplified. If you want to use the stock C5 speakers with a different HU you'd have to wire the already amplified front 'full range' signal to each 3.5, the already amplified rear 'full range' signal to each 6.5, and then wire your new HU's sub output to the audio input for the bass speakers and piggyback the HU's turn on signal wire to the amp power wires in the speakers.
Old Mar 23, 2009 | 08:21 AM
jimish's Avatar
jimish
Thanks for the help
To stereo wiring
