Sponsored by: Innova
Help Required - Kenwood Install - C5
Old Apr 4, 2009 | 04:15 PM
4 KRUSIN's Avatar
4 KRUSIN
Default Kenwood Power Supply
I just installed my Kenwood DNX 7120 and have a small question about the constant 12 V supply. There is a 15 Amp fuse on the back of the unit. Do I need to install an inline fuse in the 12V constant supply wire? Can this supply come from the cigarette lighter wire or should I run directly to the battery?
Old Apr 4, 2009 | 04:47 PM
RichDash's Avatar
RichDash
re check your ground and then your accessory with a dmm
Old Apr 9, 2009 | 11:27 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
You don't have to run an inline fuse, but it is cheap insurance. I'd rather my headunit never see that spike in current that would cook your fuse. You can use the cigarette lighter power, but I would go from the battery. I figure the odds of picking up noise is decreased that way, but I am no expert
Old Apr 10, 2009 | 10:36 AM
4 KRUSIN's Avatar
4 KRUSIN
Thanks Mr Peebody. I went directly to the battery with an inline fuse. Everything is working great except the Bluetooth. I am going to start another thread on that.
Old Apr 10, 2009 | 01:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
why not just get it from the oem harness?
Old Apr 10, 2009 | 10:51 PM
4 KRUSIN's Avatar
4 KRUSIN
Initially I got it from the OEM harness. The unit wouldn't run. At first I thought it was a bad H/U, so I took it back. They bench tested it and said it was ok.. I tested the voltages again and found that the voltage from the OEM harness was 1.5 volts less than the switched voltage. I then ran a wire directly from the battery and it worked perfectly. I am at a loss as to why the OEM wire didn't work, but at this point I don't care.
Old Apr 10, 2009 | 11:41 PM
pentavolvo's Avatar
pentavolvo
gotcha hmm i wonder what happened maybe a loose fuse or something
Old Apr 11, 2009 | 09:54 AM
4 KRUSIN's Avatar
4 KRUSIN
For anyone who is interested in a similar system, I posted more details about my install on the C5 thread at the top of the page.
Old Apr 11, 2009 | 10:09 AM
sprinter1104's Avatar
sprinter1104
Hey Krusin,
I'm planning on doing this project in the next month or so. Thanks for posting your project in the FAQ. I'm interested in more details, any tips, tricks or particulars you'd care to share concerning the installation of the head unit?
To Help Required - Kenwood Install - C5
