POP noise when power up/down
I'm using the Zuki Eleets 4 channel for both the fronts and the sub.
I'll probably try to tap into the passenger's side fuse box since it's easier to access rather than removing all the console.
Yes, I do have a multi-meter, but would you care to elaborate on that "load your woofers"?
Is there a technical way to tune the gain control for the speakers using the multimeter?
Thanks,
Dan
