Sponsored by: Innova
relay question
Old Apr 20, 2009 | 01:49 PM
jimish's Avatar
jimish
Default relay question
Quick question, To use a relay that is turned off when there is power flowing through the terminals, and then turns your accessory on when the power is cut, what terminals go where? I'm talking Bosch style relays with the #87,#86, etc terminals
Old Apr 23, 2009 | 09:58 AM
Jimmy 2 Times's Avatar
Jimmy 2 Times
What exactly are you trying to wire? If i know what you want to wire, i can help you
Old Apr 23, 2009 | 10:01 AM
Jimmy 2 Times
if you want an accessory on, (if i think this is what you want) this is how to wire it
87= 12 constant
86= acc from radio or other source
85= ground
30= what you want turned on
87a= not used
also, this is for a spdt relay
Last edited by Jimmy 2 Times; Apr 23, 2009 at 04:58 PM. Reason: corrected, this is for a spdt
Old Apr 23, 2009 | 01:11 PM
jimish's Avatar
jimish
I think thats what I need. The light switch on the blinker stalk has power going through it when it is in the off position and when it is in the parking light position. When you turn it to headlights, there is no power. I want to use this steering column in my project car, I will power the relay from a keyed on power source (#87), and when I turn the switch to headlights (#86) and there is no power it will turn on terminal #30, which I will use to power MY headlights.
Old Apr 23, 2009 | 04:59 PM
Jimmy 2 Times
i would do use the switch to headlights, that should be as 86, and the actual headlights as 30. Use 87 as the constant power source, not 12v acc
Old Apr 24, 2009 | 11:11 PM
jimish's Avatar
jimish
I wouldn't want a constant power source, but rather a keyed on source. That way when I shut the key and walk away it wont see no power from the headlight switch and turn the headlights on.
To relay question
