Sponsored by: Innova
Easy speaker wire question
Old Apr 23, 2009 | 09:49 PM
Go Vette's Avatar
Go Vette
Default Easy speaker wire question
I'm putting a simple setup in my '75 - a Pioneer head unit (22 watts per channel RMS) with new 4x6's in the dash and 6x9's out back. What gauge speaker wire would you recommend?
Old Apr 23, 2009 | 10:08 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
16 will be plenty
Old Apr 27, 2009 | 11:26 PM
samsonb's Avatar
samsonb
I'm using 16 gauge in my 89 as what was recommended. I say that is a good all around gauge to use.
I would also recommended getting some speaker wire from a car audio shop. I bought some Raptor wire for .25 a foot. I think that is cheaper speaker wire, but should be fine and was local. I probably would have bought some that was a little better .50 a foot if I knew I would be going out of town. Though, I don't believe in the hype of super expensive speaker wire.
I was recommended to just get some speaker wire from Lowes or Home Depot, but I was reading on the net where someone had bought some Lowes wire for their house speakers, and within 6 months, the clear insulation had turned green. I think the car audio speaker wire probably holds up better to the heat than house speaker wire.
Old Apr 27, 2009 | 11:55 PM
pentavolvo's Avatar
pentavolvo
homedepot 16ga all day it will be fine
IMO for generic 16ga even 25cents a foot is pusing it a bit. you can get 100 foot at homedepot for under 20 dollars
Old Apr 28, 2009 | 12:18 AM
samsonb's Avatar
samsonb
It probably would be fine. Though, I really didn't mind spending $13 for 50 feet of .25cent a foot 16 gauge car speaker wire.
Though, I've read reports of Home Depot and Lowe's speaker wire turning green. I don't believe in the hype of super expensive speaker wire. But I do believe, like everything else, there is a difference in qaulity between different brands of wire. I'm sure some wire will hold up better to heat than other wire. Some wire has thicker insulation than other wire. Some wire has less resistance than other wire of the same gauge. Some wire has more strands than other wire of the same gauge. Etc.
But again, one might not hear a difference between different brands of wire, but I don't think $13 was too much to spend on wire when I have to tear the car apart to replace it, and I don't want to do that again.
Old Apr 28, 2009 | 07:21 AM
Mike02z's Avatar
Mike02z
I can confirm that Home Depot 12ga speaker wire turns green after 3-6 months. I used this in my home system until all the wire turned green.
Old Apr 28, 2009 | 11:20 AM
pentavolvo's Avatar
pentavolvo
funny they must have changed there wire at some point i have 16ga from homedepot thats at least 5 years old in my boat and its still there and not green
Old Apr 28, 2009 | 01:43 PM
samsonb's Avatar
samsonb
Yup, I don't believe in the hype of super expensive wire. But I do believe speaker wire can be poorly constructed, made with poor materials, less strands, and less heat resistant. So, I don't buy from the bottom of the barrell.
If I was to buy speaker wire again, I would get Stinger wire. An audio shop sells it 30 miles from me for .40 cent a foot. Stinger makes several different types of speaker wire, so I say that is probably their cheaper wire as they do have some at $1+ a foot.
To Easy speaker wire question
