Sponsored by: Innova
Need Advice - C5 Bose Upgrade
Old Apr 26, 2009 | 10:27 PM
MoCityc5's Avatar
MoCityc5
Default Need Advice - C5 Bose Upgrade
I'd like to install a Pioneer Single-DIN DEHP710BT when they start shipping. I also have a 6.5" Alpine component speaker set I would like to put in place of the Bose speakers. Does it make sense to try and use the bose amps with these speakers, or do you have to take out the amps when the bose speakers come out? Also, IF I can use the bose amps, I assume that GMCRV2 adapter will still be needed. Most new HU's have RCA line-outs. Since the GMCRV2 requires speaker-level outs, is there a way to convert back to speaker-level out from line-out? Would it just be easier to install a 2-channel amp instead? Thanks for any advice.
Old Apr 26, 2009 | 10:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gmcrv2 will work with any standard headunit
no u cant use bose amp with those speakers
i recommend an aftermarket amp to get the most out of them
Old Apr 26, 2009 | 11:13 PM
MoCityc5's Avatar
MoCityc5
Ok, thanks. So do I really need the GMCRV2 if I'm pulling the Bose setup out of the front doors? Or, is it the wiring and/or the rear speakers that require the adapter?
To Need Advice - C5 Bose Upgrade
